BobMCT
- Aug 15, 2021
I've searched unsuccessfully and cannot find a solution. When I transferred all my data to the newly installed TrueNAS 12.0.U5.1 all the owner ids got changed to root and the permissions to 544 which initially is preventing virtually all access to these files. I tried as sudo using the chown -R newuser * and it seems to run with out errors. But upon completion nothing has changed. I did the same with the permissions just to see what would happen (chmod -R 774 *). I even used the shell from the TrueNAS admin page to run the same commands. Same result.
So I'm asking if anyone has run into this and overcome it in some way? Hopefully someone can provide a suggestion as to what to do.
Thanks in advance.
Thanks in advance.
