Can you extend a RAID-Z volume?
Evelen
Hi.
Lets say I start with RAID-Z1 with 3 4TB drives, 1 parity disk and two normal disk for a total 8TB capacity
Can I later add an extra drive and "upgrade" to RAID-Z2 with same capacity, or extend the RAID-Z1 to 12TB capacity?
I have read this was not possible before, but is it any changes in that the last time?
anmnz
In brief -- this is not possible and is very unlikely ever to be possible.
Correct
Disagree here; the project isn't dead and with Matt behind it, it seems likely to be released--though it's far from clear when that would be.
RAIDZ doesn't work that way (nor does any other modern RAID AFAIK)--parity is striped through the vdev. RAIDZ1 will use (approximately) one disk's worth of parity, but there is no dedicated parity disk.
Evelen
Okey, how are you suggesting I build up my storage? I can't go out buying 10 drives at the time.
I don't know where you get the "10 drives" figure; the configurations you'll most often see recommended here are:
  • Mirrors, in which case you can expand the pool by adding a pair of disks at a time; or
  • RAIDZ2 in vdevs of 6-8 disks.
A vdev of 10 disks is do-able, but about the largest you'd want to set up.
Maybe ZFS (and FreeNAS, which exclusively uses it) isn't the product for you (at least for now).
You could try Open Xpenology, which I think gives you RAID expandability (it's the open-source version of Synology).
