building tools in a separate jail or as part of the final jail?
seanshankus
Hey totally new with FreeBSD & Jails. My final goal is to build a jail that runs Universal Media Server in a jail, but they don't offer a FreeBSD port so I believe I need to fork their project and Build it. Its a maven based project so I'm sure i'll just run into whatever differences there are in dependencies may exist between the different versions of unix/linux. Maybe i'll get luckly and it works the first build. ANYWAY my question is, Do i build a seperate "building" jail of the actual UMS Jail, that has all the development libraries and what not; or just one jail that has everything? I seems you can't build directly off the host (or its HIGHLY advised against), so i'm not sure where to put the development/build stuff at?
I hope i explained this properly. My google-fu was failing me for finding a guide on how to accomplish this.
It's up to the install method you're going to use... If you will make install at the end, you're probably best having it all in the one jail. If your make creates a txz file that you will install in another jail, that's an OK approach to have a "cleaner" jail for your final product, but you may end up keeping the build jail anyway for compiling future versions.
I would just do it in the one jail if it were me.
