teqqyde
- Jan 10, 2016
at the moment i own two synology boxes (916+ and 1513+) and like to do a small performance upgrade. Additionally i like to build a rack mountable solution. So i think about some components to build my new nas.
What are my requirements:
- Filestorage for my gf and me. We are just put some photos, documents etc on this device. At the moment this will be backup to synology cloud, but i will switch to other cloud provider
- Backup target for two MacBooks via TimeMaschine
- VM Disk Hosts for my Proxmox Cluster
- max of 8 disk capacity.
So you see, that system is just for providing files, there will be no addional software be installed like plex or some other cpu intensive tasks.
Therefore i do some research and came up with the following build:
- 19" Fantac 2U Servercase (Fantec Website)
- bequite 350 W PSU
- Supermicro A2SDi-4C-HLN4F (Atom 3558)
- Samsung 16 GB RDIMM (starting with 1 dimm and expand to maximum in the next few month)
- cheap M2 SSD for System
This Systems costs me about 600 Euro here in Germany. My maximum budget is the price of a new synology 1619+, because that would be my alterative to my diy build. I don't like to buy used stuff because of warrenty. Old stuff are to power hungry. We pay about 0,28 Euro per kwh, so it sould be some sort of powerfriendly (so no Dell 510 or something like that)
A lot of people recommend my a other supermicro board with an i3 CPU. But that would be about 100 Euro more expensive (if i look for a board with 8 SATA ports - a PCI Card would use extra power and i like to avoid that). And, thats because i normally want to pay more, nobody can really tell me the performance boost of an i3 compared to the Deverton CPU. As far as i know RAM does really matter, but not cpu (in this range of build).
So, long text, but i really like to have some opinions for that build. :) Thank you!
- bequite 350 W PSU
