Best way to install Nextcloud without SSL?
Evelen
I have tried the plugin, but I find it very unstable, very slow, and it gives me a lot of http / php errors.
It is unusable. I se most people command manual setup in jail insted of using the plugin.
But do anyone have a how-to for that? I think I will go without SSL because I will try to set up SSL from my router at a later point.
Jailer
Not strong, but bad
Or you could just install the nextcloud package in a standard jail.
