I would like thank all of you for your responses, they are all very helpful. I'm doing offline tests for our needs which are split by certain read heavy and other write heavy applications. I'm doing an offline test to "learn" what I may need and verify my understanding. Once I'm comfortable with my beginner's level of knowledge, I plan on a limited live test for each scenario. I'm seasoned enough to know there will be something I may miss, but you have greatly helped me decide I may actually need at least two separate setups, whether they're in the same box or different, I'll learn as I go. When I do decide to go "all out" I will contact iXsystems for a quote and may just go TrueNAS if the budget is allows. I like the SSD as L2ARC and the SLOG device ideas are just the type of knowledge I was looking for and as an old friend used to say "mo RAM solves a lot of ills and if it don't, add mo anyway, never heard anyone say, I just got too much RAM!" Was already considering the SSD for L2ARC. The screenshot and knowing SLOG devices are mirrored and Cache devices are striped is the type of knowledge I needed. Need to shore up my understanding of SLOG devices and thier role. Nearly lost 15 years of data on a NAS device with old un-upgradable firmware due to Apple's implementation of SMB destroying the old AFP Resource Forks! You guys are AWESOME - THANKS!
