Bandwidth display on main page does not display now that i have interfaces in 2 vlans
JJensen
I have a 1gig management interface on vlan1 and 2 10gig nics bonded with LACP on vlan 175(our storage vlan). before setting up the 10gig nics everything displayed fine on the dashboard, now the bar at the top of the bandwidth section just keeps scrolling and never loads any stats. Figured id post up here and see if anyone has had this issue.
Chris Moore
What version of FreeNAS?
JJensen
screenshot
charlie89
I have the same Problem on U3. I think it worked at a time when the new UI was not finished and not the default (before 11.2), but since 11.2 the bandwith display doesn't work. It may be related with the virtualised network adapters, cause i run FreeNAS virtualised in XCP-ng.
To me this is basically no issue, cause i just go to services and enable netdata, which shows network and other statistics much more precise.
JJensen
I will upgrade to U3 and check, I am not running virtual on my build so ill let you all know if I see the same results as Charlie89.
