After successful installation and then reboot i get, timeout waiting for write drq
Hello, please help if you can.
I have:
G.SKILL NS 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory Model
4 - HITACHI Deskstar 5K3000 HDS5C3020ALA632 (0F12117) 2TB 32MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive
GIGABYTE GA-M68MT-S2P AM3 NVIDIA GeForce 7025/nForce 630a chipset Micro ATX AMD Motherboard
In a APEVIA X-QBOII X-QBOII-NW-BK/500 Black SECC Steel MicroATX Mini Tower Computer Case 500W Power Supply
With latest FreeNas8 software. on a Patriot X-Porter 2GB Flash Drive (USB2.0 Portable) Model PSF2GUSB
My issue is: I install FreeNas8 with success. I can set-up drives, write files, format drives, or just install. Then I perform a reboot(using the console). Upon reboot i get this error http://i1126.photobucket.com/albums/l620/chainsawelbows/2011-05-16_22-42-12_76.jpg it freezes right there.
I have tried multiple installs and searched the forums. Whenever I reboot the system or it goes offline, or crashes i get this reboot log.
I have tried a diferent USB drive, I have Changed IDE/AHCP settings in BIOS, I dunno
Thanks Tyler
ProtoSD
did you search the forums for "timeout waiting for DRQ"? There's a bunch of discussions about it. It's a bug.
