9.3 upgrade reboots when attaching to storage volume
crashtestmac
Hi All,
I have been using freeness now for sometime without major incident (at least after i got it going). Recently i had a failure so i took the opportunity of upgrade to 9.3.
So i can created the installer then booted up and run the install, i can get into the console but i have to manually restart njinx to get in via the web interface 6 times out of 10. But the main problem is that i cannot get 9.3 to connect to the existing volume with all my media on it. I realise from reading that i should have been backing up and copying a configuration file but i do not have that.
When i add the existing volume either from the WI or from the console it scrolls text faster than i can read and the last thing i can see before it reboots is a reset command and then is resets. The WI just shows doing step 2 of 2 and sits there forever.
Additional info
I am trying to install 9.3 onto a HP N36L micro server.
8GB of RAM, 8GB Kingston Traveller USB stick.
8TB of storage in the Array ZFS with redundancy
Any idea what is happening, and how i can get to my data...?
Many thanks
Crash
crashtestmac
I think this might be a useful log file but i am not sure....
Copyright (c) 1992-2014 The FreeBSD Project.
Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994
    The Regents of the University of California. All rights reserved.
FreeBSD is a registered trademark of The FreeBSD Foundation.
FreeBSD 9.3-RELEASE-p8 #0 r275790+4edb7b0: Fri Jan 16 14:37:13 PST 2015
    root@build3.ixsystems.com:/tank/home/jkh/build/93/FN/objs/os-base/amd64/fusion/jkh/93/FN/FreeBSD/src/sys/FREENAS.amd64 amd64
gcc version 4.2.1 20070831 patched [FreeBSD]
CPU: AMD Athlon(tm) II Neo N36L Dual-Core Processor (1297.87-MHz K8-class CPU)
  Origin = "AuthenticAMD"  Id = 0x100f63  Family = 0x10  Model = 0x6  Stepping = 3
  Features=0x178bfbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,CMOV,PAT,PSE36,CLFLUSH,MMX,FXSR,SSE,SSE2,HTT>
  Features2=0x802009<SSE3,MON,CX16,POPCNT>
  AMD Features=0xee500800<SYSCALL,NX,MMX+,FFXSR,Page1GB,RDTSCP,LM,3DNow!+,3DNow!>
  AMD Features2=0x8377f<LAHF,CMP,SVM,ExtAPIC,CR8,ABM,SSE4A,Prefetch,OSVW,IBS,SKINIT,WDT,NodeId>
  TSC: P-state invariant
real memory  = 9126805504 (8704 MB)
avail memory = 8104693760 (7729 MB)
Event timer "LAPIC" quality 400
ACPI APIC Table: <HP     ProLiant>
FreeBSD/SMP: Multiprocessor System Detected: 2 CPUs
FreeBSD/SMP: 1 package(s) x 2 core(s)
cpu0 (BSP): APIC ID:  0
cpu1 (AP): APIC ID:  1
WARNING: VIMAGE (virtualized network stack) is a highly experimental feature.
ioapic0 <Version 2.1> irqs 0-23 on motherboard
ispfw: registered firmware <isp_1040>
ispfw: registered firmware <isp_1040_it>
ispfw: registered firmware <isp_1080>
ispfw: registered firmware <isp_1080_it>
ispfw: registered firmware <isp_12160>
ispfw: registered firmware <isp_12160_it>
ispfw: registered firmware <isp_2100>
ispfw: registered firmware <isp_2200>
ispfw: registered firmware <isp_2300>
ispfw: registered firmware <isp_2322>
ispfw: registered firmware <isp_2400>
ispfw: registered firmware <isp_2400_multi>
ispfw: registered firmware <isp_2500>
ispfw: registered firmware <isp_2500_multi>
kbd1 at kbdmux0
cryptosoft0: <software crypto> on motherboard
aesni0: No AESNI support.
padlock0: No ACE support.
acpi0: <HP ProLiant> on motherboard
acpi0: Power Button (fixed)
acpi0: reservation of fee00000, 1000 (3) failed
acpi0: reservation of ffb80000, 80000 (3) failed
acpi0: reservation of fec10000, 20 (3) failed
acpi0: reservation of fed80000, 1000 (3) failed
acpi0: reservation of 0, a0000 (3) failed
acpi0: reservation of 100000, d7f00000 (3) failed
cpu0: <ACPI CPU> on acpi0
cpu1: <ACPI CPU> on acpi0
attimer0: <AT timer> port 0x40-0x43 irq 0 on acpi0
Timecounter "i8254" frequency 1193182 Hz quality 0
Event timer "i8254" frequency 1193182 Hz quality 100
atrtc0: <AT realtime clock> port 0x70-0x71 irq 8 on acpi0
Event timer "RTC" frequency 32768 Hz quality 0
hpet0: <High Precision Event Timer> iomem 0xfed00000-0xfed003ff on acpi0
Timecounter "HPET" frequency 14318180 Hz quality 950
Event timer "HPET" frequency 14318180 Hz quality 550
Event timer "HPET1" frequency 14318180 Hz quality 450
Timecounter "ACPI-safe" frequency 3579545 Hz quality 850
acpi_timer0: <32-bit timer at 3.579545MHz> port 0x808-0x80b on acpi0
pcib0: <ACPI Host-PCI bridge> port 0xcf8-0xcff on acpi0
pci0: <ACPI PCI bus> on pcib0
pcib1: <ACPI PCI-PCI bridge> at device 1.0 on pci0
pci1: <ACPI PCI bus> on pcib1
vgapci0: <VGA-compatible display> port 0xe000-0xe0ff mem 0xf0000000-0xf7ffffff,0xfe8f0000-0xfe8fffff,0xfe700000-0xfe7fffff irq 18 at device 5.0 on pci1
vgapci0: Boot video device
pcib2: <ACPI PCI-PCI bridge> irq 18 at device 6.0 on pci0
pci2: <ACPI PCI bus> on pcib2
bge0: <HP NC107i PCIe Gigabit Server Adapter, ASIC rev. 0x5784100> mem 0xfe9f0000-0xfe9fffff irq 18 at device 0.0 on pci2
bge0: CHIP ID 0x05784100; ASIC REV 0x5784; CHIP REV 0x57841; PCI-E
miibus0: <MII bus> on bge0
brgphy0: <BCM5784 10/100/1000baseT PHY> PHY 1 on miibus0
brgphy0:  10baseT, 10baseT-FDX, 100baseTX, 100baseTX-FDX, 1000baseT, 1000baseT-master, 1000baseT-FDX, 1000baseT-FDX-master, auto, auto-flow
bge0: Ethernet address: 3c:4a:92:79:bd:6c
ahci0: <AMD SB7x0/SB8x0/SB9x0 AHCI SATA controller> port 0xd000-0xd007,0xc000-0xc003,0xb000-0xb007,0xa000-0xa003,0x9000-0x900f mem 0xfe6ffc00-0xfe6fffff irq 19 at device 17.0 on pci0
ahci0: AHCI v1.20 with 4 3Gbps ports, Port Multiplier supported
ahcich0: <AHCI channel> at channel 0 on ahci0
ahcich1: <AHCI channel> at channel 1 on ahci0
ahcich2: <AHCI channel> at channel 2 on ahci0
ahcich3: <AHCI channel> at channel 3 on ahci0
ohci0: <AMD SB7x0/SB8x0/SB9x0 USB controller> mem 0xfe6fe000-0xfe6fefff irq 18 at device 18.0 on pci0
usbus0 on ohci0
ehci0: <AMD SB7x0/SB8x0/SB9x0 USB 2.0 controller> mem 0xfe6ff800-0xfe6ff8ff irq 17 at device 18.2 on pci0
usbus1: EHCI version 1.0
usbus1 on ehci0
ohci1: <AMD SB7x0/SB8x0/SB9x0 USB controller> mem 0xfe6fd000-0xfe6fdfff irq 18 at device 19.0 on pci0
usbus2 on ohci1
ehci1: <AMD SB7x0/SB8x0/SB9x0 USB 2.0 controller> mem 0xfe6ff400-0xfe6ff4ff irq 17 at device 19.2 on pci0
usbus3: EHCI version 1.0
usbus3 on ehci1
atapci0: <ATI IXP700/800 UDMA133 controller> port 0x1f0-0x1f7,0x3f6,0x170-0x177,0x376,0xff00-0xff0f at device 20.1 on pci0
ata0: <ATA channel> at channel 0 on atapci0
ata1: <ATA channel> at channel 1 on atapci0
isab0: <PCI-ISA bridge> at device 20.3 on pci0
isa0: <ISA bus> on isab0
pcib3: <ACPI PCI-PCI bridge> at device 20.4 on pci0
pci3: <ACPI PCI bus> on pcib3
ohci2: <AMD SB7x0/SB8x0/SB9x0 USB controller> mem 0xfe6fc000-0xfe6fcfff irq 18 at device 22.0 on pci0
usbus4 on ohci2
ehci2: <AMD SB7x0/SB8x0/SB9x0 USB 2.0 controller> mem 0xfe6ff000-0xfe6ff0ff irq 17 at device 22.2 on pci0
usbus5: EHCI version 1.0
usbus5 on ehci2
amdtemp0: <AMD CPU On-Die Thermal Sensors> on hostb4
acpi_button0: <Power Button> on acpi0
sc0: <System console> at flags 0x100 on isa0
sc0: VGA <16 virtual consoles, flags=0x300>
vga0: <Generic ISA VGA> at port 0x3c0-0x3df iomem 0xa0000-0xbffff on isa0
wbwd0: HEFRAS and EFER do not align: EFER 0x2e DevID 0xff DevRev 0xff CR26 0xff
acpi_throttle0: <ACPI CPU Throttling> on cpu0
hwpstate0: <Cool`n'Quiet 2.0> on cpu0
ZFS filesystem version: 5
ZFS storage pool version: features support (5000)
Timecounters tick every 1.000 msec
ipfw2 (+ipv6) initialized, divert enabled, nat enabled, default to accept, logging disabled
usbus0: 12Mbps Full Speed USB v1.0
usbus1: 480Mbps High Speed USB v2.0
usbus2: 12Mbps Full Speed USB v1.0
usbus3: 480Mbps High Speed USB v2.0
usbus4: 12Mbps Full Speed USB v1.0
usbus5: 480Mbps High Speed USB v2.0
ugen0.1: <ATI> at usbus0
uhub0: <ATI OHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus0
ugen1.1: <ATI> at usbus1
uhub1: <ATI EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus1
ugen2.1: <ATI> at usbus2
uhub2: <ATI OHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus2
ugen3.1: <ATI> at usbus3
uhub3: <ATI EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus3
ugen4.1: <ATI> at usbus4
uhub4: <ATI OHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus4
ugen5.1: <ATI> at usbus5
uhub5: <ATI EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus5
uhub4: 4 ports with 4 removable, self powered
uhub0: 5 ports with 5 removable, self powered
uhub2: 5 ports with 5 removable, self powered
uhub5: 4 ports with 4 removable, self powered
uhub1: 5 ports with 5 removable, self powered
uhub3: 5 ports with 5 removable, self powered
ugen0.2: <DELL> at usbus0
ukbd0: <DELL Dell QuietKey Keyboard, class 0/0, rev 1.10/1.01, addr 2> on usbus0
kbd0 at ukbd0
ugen1.2: <Kingston> at usbus1
umass0: <Kingston DataTraveler 2.0, class 0/0, rev 2.00/1.00, addr 2> on usbus1
umass0:  SCSI over Bulk-Only; quirks = 0xc101
umass0:7:0:-1: Attached to scbus7
uhub_explore: illegal enable change, port 4
ada0 at ahcich0 bus 0 scbus0 target 0 lun 0
ada0: <SAMSUNG HD204UI 1AQ10001> ATA-8 SATA 2.x device
ada0: Serial Number S2H7JD1B216379
ada0: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
ada0: Command Queueing enabled
ada0: 1907729MB (3907029168 512 byte sectors: 16H 63S/T 16383C)
ada0: quirks=0x1<4K>
da0 at umass-sim0 bus 0 scbus7 target 0 lun 0
da0: <Kingston DataTraveler 2.0 1.00> Removable Direct Access SCSI-4 device
da0: Serial Number 00173189745CCE4089EC5377
da0: 40.000MB/s transfers
da0: 7396MB (15148608 512 byte sectors: 255H 63S/T 942C)
da0: quirks=0x3<NO_SYNC_CACHE,NO_6_BYTE>
ada0: Previously was known as ad4
ada1 at ahcich1 bus 0 scbus1 target 0 lun 0
ada1: <SAMSUNG HD204UI 1AQ10001> ATA-8 SATA 2.x device
ada1: Serial Number S2H7JD1B216491
ada1: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
ada1: Command Queueing enabled
ada1: 1907729MB (3907029168 512 byte sectors: 16H 63S/T 16383C)
ada1: quirks=0x1<4K>
ada1: Previously was known as ad6
ada2 at ahcich2 bus 0 scbus2 target 0 lun 0
ada2: <SAMSUNG HD203WI 1AN10003> ATA-8 SATA 2.x device
ada2: Serial Number S1UYJ1BZ701951
ada2: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
ada2: Command Queueing enabled
ada2: 1907729MB (3907029168 512 byte sectors: 16H 63S/T 16383C)
ada2: Previously was known as ad8
ada3 at ahcich3 bus 0 scbus3 target 0 lun 0
ada3: <SAMSUNG HD203WI 1AN10003> ATA-8 SATA 2.x device
ada3: Serial Number S1UYJ1BZ701947
ada3: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
ada3: Command Queueing enabled
ada3: 1907728MB (3907027055 512 byte sectors: 16H 63S/T 16383C)
ada3: Previously was known as ad10
SMP: AP CPU #1 Launched!
Timecounter "TSC" frequency 1297870265 Hz quality 800
Trying to mount root from zfs:freenas-boot/ROOT/default []...
<118>Loading early kernel modules:
GEOM_RAID5: Module loaded, version 1.3.20140711.62 (rev f91e28e40bf7)
<118>savecore: reboot after panic: Solaris(panic): zfs: allocating allocated segment(offset=70666665984 size=16384)
<118>savecore: unable to write to bounds file: Read-only file system
<118>savecore: : Read-only file system
<118>savecore: unsaved dumps found but not saved
<118>/data/crash/vmcore.2 not found
<118>Setting hostuuid: 128c1267-cc40-11df-9f37-3c4a9279bd6c.
<118>Setting hostid: 0x6eeb6661.
<118>No suitable dump device was found.
<118>Entropy harvesting: interrupts ethernet point_to_point kickstart.
<118>Starting file system checks:
<118>Mounting local file systems:.
<118>Loading kernel modules:
ipmi0: <IPMI System Interface> on isa0
ipmi0: KCS mode found at mem 0x0 alignment 0x1 on isa
ipmi0: couldn't configure I/O resource
device_attach: ipmi0 attach returned 6
<118>Setting hostname: freenas.local.
<118>Starting Network: lo0 bge0 ipfw0.
<118>lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> metric 0 mtu 16384
<118>    options=600003<RXCSUM,TXCSUM,RXCSUM_IPV6,TXCSUM_IPV6>
<118>    inet6 ::1 prefixlen 128
<118>    inet6 fe80::1%lo0 prefixlen 64 scopeid 0x9
<118>    inet 127.0.0.1 netmask 0xff000000
<118>    nd6 options=21<PERFORMNUD,AUTO_LINKLOCAL>
<118>bge0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
<118>    options=c019b<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,TSO4,VLAN_HWTSO,LINKSTATE>
<118>    ether 3c:4a:92:79:bd:6c
<118>    inet 192.168.0.10 netmask 0xffffff00 broadcast 192.168.0.255
<118>    nd6 options=9<PERFORMNUD,IFDISABLED>
<118>    media: Ethernet autoselect (none)
<118>    status: no carrier
<118>ipfw0: flags=8801<UP,SIMPLEX,MULTICAST> metric 0 mtu 65536
<118>Starting devd.
<118>add net default: gateway 192.168.0.1
<118>add net fe80::: gateway ::1
<118>add net ff02::: gateway ::1
<118>add net ::ffff:0.0.0.0: gateway ::1
<118>add net ::0.0.0.0: gateway ::1
<118>Generating host.conf.
<118>ELF ldconfig path: /lib /usr/lib /usr/local/lib /usr/local/lib/gcc47 /usr/local/lib/nss
<118>32-bit compatibility ldconfig path:
<118>ls: /var/db/system: No such file or directory
<118>Creating and/or trimming log files.
<118>Starting syslog_ng.
<118>Starting watchdogd.
<118>watchdogd: watchdog_patpat failed: Operation not supported
<118>watchdogd: patting the dog: Operation not supported
<118>/etc/rc: WARNING: failed to start watchdogd
<118>debug.ddb.textdump.pending: 0 -> 1
<118>debug.debugger_on_panic: 1 -> 1
<118>Jan 18 21:09:01 freenas savecore: reboot after panic: Solaris(panic): zfs: allocating allocated segment(offset=70666665984 size=16384)
<118>savecore: writing compressed core to /data/crash/textdump.tar.3.gz
<118>/data/crash/vmcore.3 not found
<118>/etc/rc: WARNING: failed precmd routine for vmware_guestd
vboxdrv: fAsync=0 offMin=0x377 offMax=0x8a6
<118>Updating motd:.
<118>Starting ntpd.
<6>pid 1907 (python2.7), uid 0: exited on signal 11 (core dumped)
<118>Segmentation fault (core dumped)
<118>Importing account for root...ok
<118>
<118>Granted SeTakeOwnershipPrivilege to FREENAS\root
<118>Granted SeBackupPrivilege to FREENAS\root
<118>Granted SeRestorePrivilege to FREENAS\root
<118>
<118>Starting smartd.
<118>Jan 18 21:10:03 freenas smartd[2105]: Device: /dev/ada0, WARNING: Using smartmontools or hdparm with this
<118>Jan 18 21:10:03 freenas smartd[2105]: drive may result in data loss due to a firmware bug.
<118>Jan 18 21:10:03 freenas smartd[2105]: ****** THIS DRIVE MAY OR MAY NOT BE AFFECTED! ******
<118>Jan 18 21:10:03 freenas smartd[2105]: Buggy and fixed firmware report same version number!
<118>Jan 18 21:10:03 freenas smartd[2105]: See the following web pages for details:
<118>Jan 18 21:10:03 freenas smartd[2105]: http://knowledge.seagate.com/articles/en_US/FAQ/223571en
<118>Jan 18 21:10:03 freenas smartd[2105]: http://www.smartmontools.org/wiki/SamsungF4EGBadBlocks
<118>Jan 18 21:10:05 freenas smartd[2105]: Device: /dev/ada1, WARNING: Using smartmontools or hdparm with this
<118>Jan 18 21:10:05 freenas smartd[2105]: drive may result in data loss due to a firmware bug.
<118>Jan 18 21:10:05 freenas smartd[2105]: ****** THIS DRIVE MAY OR MAY NOT BE AFFECTED! ******
<118>Jan 18 21:10:05 freenas smartd[2105]: Buggy and fixed firmware report same version number!
<118>Jan 18 21:10:05 freenas smartd[2105]: See the following web pages for details:
<118>Jan 18 21:10:05 freenas smartd[2105]: http://knowledge.seagate.com/articles/en_US/FAQ/223571en
<118>Jan 18 21:10:05 freenas smartd[2105]: http://www.smartmontools.org/wiki/SamsungF4EGBadBlocks
<118>Starting pbid...
<118>Performing sanity check on nginx configuration:
<118>nginx: the configuration file /usr/local/etc/nginx/nginx.conf syntax is ok
<118>nginx: configuration file /usr/local/etc/nginx/nginx.conf test is successful
<118>Starting nginx.
<118>Starting mdnsd.
<118>Starting netatalk.
<118>Starting dbus.
<118>Starting collectd.
<118>Performing sanity check on sshd configuration.
<118>Starting sshd.
<118>Flushed all rules.
<118>Waiting up to 5 seconds for ixdiagnose to finish... 5 4 done.
<6>pid 2964 (python2.7), uid 0: exited on signal 11 (core dumped)
<6>pid 3032 (python2.7), uid 0: exited on signal 11 (core dumped)
<118>Configuring syscons: blanktime.
<118>Starting cron.
<118>
<118>Sun Jan 18 21:11:40 GMT 2015
<6>pid 3336 (python2.7), uid 0: exited on signal 11 (core dumped)
<6>pid 3501 (python2.7), uid 0: exited on signal 11 (core dumped)
<6>pid 3515 (python2.7), uid 0: exited on signal 11 (core dumped)
cpuid = 0
KDB: stack backtrace:
db_trace_self_wrapper() at db_trace_self_wrapper+0x2a/frame 0xffffff8247d843c0
kdb_backtrace() at kdb_backtrace+0x37/frame 0xffffff8247d84480
panic() at panic+0x1ce/frame 0xffffff8247d84580
vcmn_err() at vcmn_err+0x6b/frame 0xffffff8247d846b0
zfs_panic_recover() at zfs_panic_recover+0x7a/frame 0xffffff8247d84790
range_tree_add() at range_tree_add+0x168/frame 0xffffff8247d84830
space_map_load() at space_map_load+0x332/frame 0xffffff8247d848c0
metaslab_load() at metaslab_load+0x3b/frame 0xffffff8247d848f0
metaslab_activate() at metaslab_activate+0x5a/frame 0xffffff8247d84920
metaslab_alloc() at metaslab_alloc+0x61f/frame 0xffffff8247d84a50
zio_dva_allocate() at zio_dva_allocate+0x9b/frame 0xffffff8247d84b20
zio_execute() at zio_execute+0xbd/frame 0xffffff8247d84b70
taskqueue_run_locked() at taskqueue_run_locked+0x74/frame 0xffffff8247d84bc0
taskqueue_thread_loop() at taskqueue_thread_loop+0x55/frame 0xffffff8247d84be0
fork_exit() at fork_exit+0x11f/frame 0xffffff8247d84c30
fork_trampoline() at fork_trampoline+0xe/frame 0xffffff8247d84c30
--- trap 0, rip = 0, rsp = 0xffffff8247d84cf0, rbp = 0 ---
KDB: enter: panic
crashtestmac
Panic.txt
Version.txt
You know the forum rules? The ones you said you read and agreed to when you joined? They're a red link at the top of the page, in case you've forgotten. I'd suggest reading them to give you an idea of what's missing from your post.
crashtestmac
Sorry for missing out information, i have added what i can and will add more when i get home this evening.
crashtestmac
Here is more information that i think might be needed.
dmesg
kbd1 at kbdmux0
Timecounter "ACPI-fast" frequency 3579545 Hz quality 900
usbus0 on ohci0
usbus1 on ehci0
usbus2 on ohci1
usbus3 on ehci1
usbus4 on ohci2
usbus5 on ehci2
kbd0 at ukbd0
umass0:  SCSI over Bulk-Only; quirks = 0xc100
Timecounter "TSC" frequency 1297866219 Hz quality 800
vboxdrv: fAsync=0 offMin=0x37d offMax=0x2c1d
pid 1670 (python2.7), uid 0: exited on signal 10 (core dumped)
pid 2330 (python2.7), uid 0: exited on signal 10 (core dumped)
pid 3289 (python2.7), uid 0: exited on signal 11 (core dumped)
pid 3370 (python2.7), uid 0: exited on signal 10 (core dumped)
pid 3626 (python2.7), uid 0: exited on signal 11 (core dumped)
pid 3837 (python2.7), uid 0: exited on signal 10 (core dumped)
pid 3864 (python2.7), uid 0: exited on signal 11 (core dumped)
cpuid = 0
db_trace_self_wrapper() at db_trace_self_wrapper+0x2a/frame 0xffffff8247d583c0
kdb_backtrace() at kdb_backtrace+0x37/frame 0xffffff8247d58480
panic() at panic+0x1ce/frame 0xffffff8247d58580
vcmn_err() at vcmn_err+0x6b/frame 0xffffff8247d586b0
zfs_panic_recover() at zfs_panic_recover+0x7a/frame 0xffffff8247d58790
range_tree_add() at range_tree_add+0x168/frame 0xffffff8247d58830
space_map_load() at space_map_load+0x332/frame 0xffffff8247d588c0
metaslab_load() at metaslab_load+0x3b/frame 0xffffff8247d588f0
metaslab_activate() at metaslab_activate+0x5a/frame 0xffffff8247d58920
metaslab_alloc() at metaslab_alloc+0x61f/frame 0xffffff8247d58a50
zio_dva_allocate() at zio_dva_allocate+0x9b/frame 0xffffff8247d58b20
zio_execute() at zio_execute+0xbd/frame 0xffffff8247d58b70
taskqueue_run_locked() at taskqueue_run_locked+0x74/frame 0xffffff8247d58bc0
taskqueue_thread_loop() at taskqueue_thread_loop+0x55/frame 0xffffff8247d58be0
fork_exit() at fork_exit+0x11f/frame 0xffffff8247d58c30
fork_trampoline() at fork_trampoline+0xe/frame 0xffffff8247d58c30
--- trap 0, rip = 0, rsp = 0xffffff8247d58cf0, rbp = 0 ---
KDB: enter: panic
kbd1 at kbdmux0
usbus0 on ohci0
usbus1 on ehci0
usbus2 on ohci1
usbus3 on ehci1
usbus4 on ohci2
usbus5 on ehci2
kbd0 at ukbd0
Timecounter "TSC" frequency 1297865256 Hz quality 800
vboxdrv: fAsync=0 offMin=0x371 offMax=0x942
pid 1979 (python2.7), uid 0: exited on signal 11 (core dumped)
pid 2037 (python2.7), uid 0: exited on signal 11 (core dumped)
pid 3377 (python2.7), uid 0: exited on signal 11 (core dumped)
pid 3488 (python2.7), uid 0: exited on signal 11 (core dumped)
bge0: link state changed to DOWN
bge0: link state changed to UP
pid 2451 (python2.7), uid 0: exited on signal 11 (core dumped)
crashtestmac
If i restart the server at the console i have to reset the network configuration to get it to use DHCP and pick up an address, once this happenes the Webinterface comes online.
If i go to storage i can add the volume this starts the wizard about encryption, i say no just carry on then it detects the storage volume. It is a ZFS volume with parity (like raid 5 i think).
It thinks about it for 10 seconds in the webgui and then on the console i can just see text scrolling at the speed of light.
How can i find out what is failing and can i get back into my data, please help me someone....!
Thanks
Crash
What's the output (in code tags) of zpool import? Do you still have your old boot USB? If so, will it boot and import/mount the pool without problems?
crashtestmac
[root@freenas] ~# zpool import
   pool: tank
  state: ONLINE
status: The pool was last accessed by another system.
action: The pool can be imported using its name or numeric identifier and
    the '-f' flag.
   see: http://illumos.org/msg/ZFS-8000-EY
    tank                                            ONLINE
      raidz1-0                                      ONLINE
        gptid/0075529f-4b30-11e4-8cc0-3c4a9279bd6c  ONLINE
        gptid/0121c5c0-4b30-11e4-8cc0-3c4a9279bd6c  ONLINE
        gptid/01cbdecc-4b30-11e4-8cc0-3c4a9279bd6c  ONLINE
        gptid/02cf88d7-4b30-11e4-8cc0-3c4a9279bd6c  ONLINE
[root@freenas] ~# zpool import -f
   pool: tank
  state: ONLINE
    the '-f' flag.
    tank                                            ONLINE
      raidz1-0                                      ONLINE
crashtestmac
running
zpool import -f tank
causes the failure again and the system to scroll the text and reboot.
crashtestmac
no that usb failed, which is what started the upgrade process to 9.3
I have read the Freeness powerpoint guide and have realised that i am short on RAM i have 8gb and 6tb of storage so i think i am short on RAM still.if i download a 9.2 is it likely to connect...?
crashtestmac
These are the results of what it says to run.
[root@freenas] ~# zpool status
  pool: freenas-boot
state: ONLINE
  scan: none requested
    NAME                                          STATE     READ WRITE CKSUM
    freenas-boot                                  ONLINE       0     0     0
      gptid/866d3808-cc3d-11df-8244-3c4a9279bd6c  ONLINE       0     0     0
errors: No known data errors
[root@freenas] ~# zfs get mountpoint
NAME        PROPERTY    VALUE       SOURCE
freenas-boot                                                           mountpoint  none        local
freenas-boot/ROOT                                                      mountpoint  none        inherited from freenas-boot
freenas-boot/ROOT/FreeNAS-9.3-STABLE-201501241715                      mountpoint  /           local
freenas-boot/ROOT/FreeNAS-9.3-STABLE-201501241715@2015-01-26-20:15:07  mountpoint  -           -
freenas-boot/ROOT/default                                              mountpoint  legacy      local
freenas-boot/grub                                                      mountpoint  legacy      local
freenas-boot/grub@Pre-Upgrade-FreeNAS-9.3-STABLE-201501241715          mountpoint  -           -
[root@freenas] ~#
crashtestmac
What does this mean in english..?
we solved the problem, for us it was the name of the zpool corresponding with the mountpoint of a folder of the freenas filesystem.
because of the name of our pool DATA it wanted to mount the zpool to the /data mountpoint in the OS wich is the DATA folder of Freenas it self.
we changed the name of the zpool import pool and mounted it to /tmp so we could get to the files
can you do a zpool status and zfs get mountpoint and post the information here?
to change the name of the zpool import OLDPOOLNAME NEWPOOLNAME
