***Updates in post #7 below***
The time has come for me to build a new box from scratch. I'm finally taking the ECC plunge. The server is for home use, typically 1-3 simultaneous users. The NAS is primarily for backups and serving media to my HTPC and other network clients. I plan to build a system that's a bit overpowered for my current needs in the hopes of future-proofing. I'm willing to spend money for quality--not looking to necessarily minimize cost. Here's what I'm considering in terms of parts, along with some of my thought process. I'd really appreciate any comments, advice, and/or suggestions.
Processor: Intel Xeon E3-1230v3
I don't transcode currently, but want that option available to me. I don't currently run any plugins/jails, but definitely want to explore that in the future too.
Motherboard: Supermicro X10SLH-F
The only other board I'm considering is the X10SLM-F. I think I like the SLH a little better for the 6x SATA3 ports (I know the HDDs I'm going with won't even max out SATA2 ports, but...future-proofing. The SLM has 2xSATA2 and 4xSATA3). I'm having a tough time figuring out the differences between the on-board Intel NICs, but I'm pretty sure I'll only be using one of them anyway, so that might not matter too much to me. The other differences I see between the 2 boards are:
I'll run these in a RAIDZ2. 5400 RPM is plenty, and I'll be sure to review the WDIDLE situation to properly set the park timers.
RAM:TBD, but I'll definitely be getting something off the Supermicro compatibility/tested list. I'm thinking of starting off with 16GB total (2x8GB, so I can easily move to 32GB if 16GB isn't enough). I've skimmed the Kingston travesty thread, so I think I'll stay away from that brand.
PSU:TBD. I haven't done the math yet. I'm definitely going with something that's 80Plus Gold certified. Seems like I'll never see the benefit of Platinum over Gold.
Chassis: I'm leaning towards the Fractal Design Define R4. I'm not looking for tiny, but I don't have space for a rack. This case with only 6 HDDs and no add-on cards should leave me in a decent situation in terms of airflow/cooling.
I think that covers it. Please take a look and let me know if I'm overlooking anything.
- RAM voltage: the SLM supports 1.35V in addition to 1.5V while the SLH only supports 1.5V, but I'm not going for low power (necessarily), and I know I can use sticks of either voltage in the SLH board.
- Chipset: Intel C226 on the SLH and C224 on the SLM. I don't really mind paying a bit extra for the C226...future-proofing
RAM:
PSU:
