I'm trying to install Sabnzbd in a standard jail instead of the plugin. I copied my sabnzbd.ini file and it is working but my file permissions are not correct. I believe the default user/group is _sabnzbd/_sabnzbd and my media files are media/media.
I believe I need a version of this command but I'm not sure what it should be. Any help would be appreiciated.
https://forums.freenas.org/index.ph...to-install-plex-in-a-freenas-9-10-jail.19412/
The column with 1002 is the UserID, and 1001 is the GroupID. If you want Plex to have access to the Media mount, you need need to create the Media group in the jail with a GroupID of 1001, and have the plex user in it.
To do this, run the following command (where 1001 is the GroupID):
pw groupadd Media -g 1001 && pw usermod plex -G plex,Media
