I'm trying to get openVPN (in client mode) working in a Transmission plugin jail created in 11.3-U1. I've followed the following guides, but have not been successful and believe I have some kind of DNS issue.
www.ixsystems.com
www.ixsystems.com
I have been able to install and configure the openvpn client to connect/authenticate with my VPN provider, NordVPN.
However the VPN does not appear to work. Once the VPN is connected, I am not able to ping / drill / wget any services using domain names. However when I try these commands with IP addresses of the domains, the commands return sensible data. See below.
Before I try and get IPFW configured, I want to ensure the VPN is working. Does anybody have any ideas on what could be happening or suggestions on what I should be investigating to get the VPN functioning normally?
Please note the last command in the code above is actually returning the public IP of the VPN service. This is not my home networks public IP.
Some further information that may help is as follows:
My home private network is on 10.0.0.0/24 (255.255.255.0)
My modem/router/gateway is 10.0.0.138.
My FreeNAS server is 10.0.0.17.
The Transmission plugin jail appears to be on 172.16.0.0/30
The Transmission plugin jail is 172.16.02 (It is using NAT within FreeNAS)
The NordVPN private network looks to be 10.8.8.0/24 (255.255.255.0)
The NordVPN DNS Servers are = 103.86.96.100 and 103.86.99.100.
Once the VPN is connected, I am unable to access the Transmission GUI at http://10.0.0.17:9091 from other devices on my local LAN.
Transmission jail is set up with allow_tun selected in the custom properties and the following port forwarding within the jail:
tcp 9091(jail) ->9091(host) for transmission GUI
udp 1194(jail) ->1194(host) for openVPN connection to NordVPN
After executing:
The logs in /var/log/messages are:
[GUIDE] VPN Killswitch inside of jail
This is a bit of a work in progress. But for anyone who pays or uses openvpn to connect to a client and would like to prevent anything from leaking out into the world, I am using UFW to block all outgoing data, except through the VPN tunnel. I originally did this in my router, but the poor...
![www.ixsystems.com](https://www.truenas.com/community/data/assets/logo/FORUMSFAVICON.png)
How to use Openvpn & ipfw in a jail so it only connects to the VPN
I wanted to use Openvpn with my Transmission plugin but didn't want any of my other network traffic to go through the VPN. Additionally, I didn't want Transmission to access the internet except through the VPN. This "how-to" assumes you have a VPN service you're connecting to and have downloaded...
root@transmission:~ # drill google.com Error: error sending query: Could not send or receive, because of network error root@transmission:~ # ping google.com ping: cannot resolve google.com: Host name lookup failure root@transmission:~ # wget -qO - http://wtfismyip.com/text root@transmission:~ # ping 216.58.203.110 PING 216.58.203.110 (216.58.203.110): 56 data bytes 64 bytes from 216.58.203.110: icmp_seq=0 ttl=57 time=7.108 ms 64 bytes from 216.58.203.110: icmp_seq=1 ttl=57 time=7.564 ms 64 bytes from 216.58.203.110: icmp_seq=2 ttl=57 time=7.842 ms ^C --- 216.58.203.110 ping statistics --- 6 packets transmitted, 6 packets received, 0.0% packet loss round-trip min/avg/max/stddev = 7.108/11.493/30.780/8.631 ms root@transmission:~ # wget -qO - http://69.195.159.158/text 144.48.36.4
After executing:
root@transmission:~ # service openvpn start
Apr 20 00:59:47 transmission openvpn[25415]: OpenVPN 2.4.8 amd64-portbld-freebsd11.3 [SSL (OpenSSL)] [LZO] [LZ4] [MH/RECVDA] [AEAD] built on Mar 31 2020 Apr 20 00:59:47 transmission openvpn[25415]: library versions: OpenSSL 1.0.2s-freebsd 28 May 2019, LZO 2.10 Apr 20 00:59:47 transmission openvpn[25416]: WARNING: --ping should normally be used with --ping-restart or --ping-exit Apr 20 00:59:47 transmission openvpn[25416]: Outgoing Control Channel Authentication: Using 512 bit message hash 'SHA512' for HMAC authentication Apr 20 00:59:47 transmission openvpn[25416]: Incoming Control Channel Authentication: Using 512 bit message hash 'SHA512' for HMAC authentication Apr 20 00:59:47 transmission openvpn[25416]: TCP/UDP: Preserving recently used remote address: [AF_INET]144.48.36.3:1194 Apr 20 00:59:47 transmission openvpn[25416]: Socket Buffers: R=[42080->42080] S=[9216->9216] Apr 20 00:59:47 transmission openvpn[25416]: UDP link local: (not bound) Apr 20 00:59:47 transmission openvpn[25416]: UDP link remote: [AF_INET]144.48.36.3:1194 Apr 20 00:59:47 transmission openvpn[25416]: TLS: Initial packet from [AF_INET]144.48.36.3:1194, sid=7d86a5dd 631f146f Apr 20 00:59:47 transmission openvpn[25416]: WARNING: this configuration may cache passwords in memory -- use the auth-nocache option to prevent this Apr 20 00:59:47 transmission openvpn[25416]: VERIFY OK: depth=2, C=PA, O=NordVPN, CN=NordVPN Root CA Apr 20 00:59:47 transmission openvpn[25416]: VERIFY OK: depth=1, C=PA, O=NordVPN, CN=NordVPN CA4 Apr 20 00:59:47 transmission openvpn[25416]: VERIFY KU OK Apr 20 00:59:47 transmission openvpn[25416]: Validating certificate extended key usage Apr 20 00:59:47 transmission openvpn[25416]: ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication Apr 20 00:59:47 transmission openvpn[25416]: VERIFY EKU OK Apr 20 00:59:47 transmission openvpn[25416]: VERIFY OK: depth=0, CN=au263.nordvpn.com Apr 20 00:59:47 transmission openvpn[25416]: Control Channel: TLSv1.2, cipher TLSv1/SSLv3 ECDHE-RSA-AES256-GCM-SHA384, 4096 bit RSA Apr 20 00:59:47 transmission openvpn[25416]: [au263.nordvpn.com] Peer Connection Initiated with [AF_INET]144.48.36.3:1194 Apr 20 00:59:48 transmission openvpn[25416]: SENT CONTROL [au263.nordvpn.com]: 'PUSH_REQUEST' (status=1) Apr 20 00:59:48 transmission openvpn[25416]: PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 103.86.96.100,dhcp-option DNS> Apr 20 00:59:48 transmission openvpn[25416]: OPTIONS IMPORT: timers and/or timeouts modified Apr 20 00:59:48 transmission openvpn[25416]: OPTIONS IMPORT: explicit notify parm(s) modified Apr 20 00:59:48 transmission openvpn[25416]: OPTIONS IMPORT: compression parms modified Apr 20 00:59:48 transmission openvpn[25416]: OPTIONS IMPORT: --sndbuf/--rcvbuf options modified Apr 20 00:59:48 transmission openvpn[25416]: Socket Buffers: R=[42080->524288] S=[9216->524288] Apr 20 00:59:48 transmission openvpn[25416]: OPTIONS IMPORT: --ifconfig/up options modified Apr 20 00:59:48 transmission openvpn[25416]: OPTIONS IMPORT: route options modified Apr 20 00:59:48 transmission openvpn[25416]: OPTIONS IMPORT: route-related options modified Apr 20 00:59:48 transmission openvpn[25416]: OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified Apr 20 00:59:48 transmission openvpn[25416]: OPTIONS IMPORT: peer-id set Apr 20 00:59:48 transmission openvpn[25416]: OPTIONS IMPORT: adjusting link_mtu to 1657 Apr 20 00:59:48 transmission openvpn[25416]: OPTIONS IMPORT: data channel crypto options modified Apr 20 00:59:48 transmission openvpn[25416]: Data Channel: using negotiated cipher 'AES-256-GCM' Apr 20 00:59:48 transmission openvpn[25416]: Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key Apr 20 00:59:48 transmission openvpn[25416]: Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key Apr 20 00:59:48 transmission openvpn[25416]: ROUTE_GATEWAY 172.16.0.1/255.255.255.252 IFACE=epair0b HWADDR=3c:d9:2b:03:aa:47 Apr 20 00:59:48 transmission openvpn[25416]: TUN/TAP device /dev/tun0 opened Apr 20 00:59:48 transmission openvpn[25416]: /sbin/ifconfig tun0 10.8.8.20 10.8.8.1 mtu 1500 netmask 255.255.255.0 up Apr 20 00:59:48 transmission openvpn[25416]: /sbin/route add -net 10.8.8.0 10.8.8.1 255.255.255.0 Apr 20 00:59:48 transmission openvpn[25416]: /sbin/route add -net 144.48.36.3 172.16.0.1 255.255.255.255 Apr 20 00:59:48 transmission openvpn[25416]: /sbin/route add -net 0.0.0.0 10.8.8.1 128.0.0.0 Apr 20 00:59:48 transmission openvpn[25416]: /sbin/route add -net 128.0.0.0 10.8.8.1 128.0.0.0 Apr 20 00:59:49 transmission openvpn[25416]: Initialization Sequence Completed
root@transmission:~ # ifconfig lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> metric 0 mtu 16384 options=680003<RXCSUM,TXCSUM,LINKSTATE,RXCSUM_IPV6,TXCSUM_IPV6> inet6 ::1 prefixlen 128 inet6 fe80::1%lo0 prefixlen 64 scopeid 0x1 inet 127.0.0.1 netmask 0xff000000 nd6 options=21<PERFORMNUD,AUTO_LINKLOCAL> groups: lo epair0b: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=8<VLAN_MTU> ether 3c:d9:2b:03:aa:47 hwaddr 02:a0:76:00:07:0b inet 172.16.0.2 netmask 0xfffffffc broadcast 172.16.0.3 nd6 options=1<PERFORMNUD> media: Ethernet 10Gbase-T (10Gbase-T <full-duplex>) status: active groups: epair tun0: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> metric 0 mtu 1500 options=80000<LINKSTATE> inet 10.8.8.20 --> 10.8.8.1 netmask 0xffffff00 nd6 options=1<PERFORMNUD> groups: tun Opened by PID 25416
root@transmission:~ # cat /etc/resolv.conf # Generated by resolvconf search local gateway nameserver 10.0.0.138
root@transmission:~ # netstat -rn Routing tables Internet: Destination Gateway Flags Netif Expire 0.0.0.0/1 10.8.8.1 UGS tun0 default 172.16.0.1 UGS epair0b 10.8.8.0/24 10.8.8.1 UGS tun0 10.8.8.1 link#3 UH tun0 10.8.8.20 link#3 UHS lo0 127.0.0.1 link#1 UH lo0 128.0.0.0/1 10.8.8.1 UGS tun0 144.48.36.3/32 172.16.0.1 UGS epair0b 172.16.0.0/30 link#2 U epair0b 172.16.0.2 link#2 UHS lo0 Internet6: Destination Gateway Flags Netif Expire ::/96 ::1 UGRS lo0 ::1 link#1 UH lo0 ::ffff:0.0.0.0/96 ::1 UGRS lo0 fe80::/10 ::1 UGRS lo0 fe80::%lo0/64 link#1 U lo0 fe80::1%lo0 link#1 UHS lo0 ff02::/16 ::1 UGRS lo0 root@transmission:~ #
