As per the title, I have OneDrive Personal working as a Cloud Sync task in TrueNAS-12.0-U2.1 but can't get OneDrive Business working.
When I set up the credentials through the GUI, it comes in initially as Personal. If I go to Drives List, there is a DOCUMENT_LIBRARY option, which I select and it fills in the Drive ID. Clicking on Verify Credential comes back as 'valid'.
When I set up the cloud sync task, if I click on the Folder View below the Credential, it's empty (there should be four folders there). If I attempt a dry run, it doesn't throw any errors but just says there is nothing to do. I can create files and folders on OneDrive and it still says there is nothing to do.
