Copy the
if_atlantic.ko
to /boot/modules - from outside of the jail. This will not do any harm.
Then you can try to dynamically load the module:
kldload if_atlantic
If that does not instantly crash your FreeNAS - which is entirely possible - these commands will show you if the interface is detected:
dmesg
kldstat
ifconfig -a
To load the driver automatically at startup you can create a Tunable in the UI. Type: "loader", Variable: "if_atlantic_load", Value: "YES".
You will have to copy the module after each update!
The interface will then show up in the UI and will be configurable like any other.
HTH,
Patrick
