Luis Miguel
- Dec 25, 2016
Versions:
FreeNAS-11.2-BETA1
Airsonic 10.1.2 Stand-alone WAR (all platforms)
iocage jail (11.1-RELEASE-p6)
*** Create airsonic iocage ***
*** Add storage ***
*** Some troubleshooting commands ***
*** Enter airsonic jail ***
*** Install packages ***
*** OPTIONAL - Copy configuration from old warden jail to new iocage jail ***
*** Install ffmpeg dependencies and Ports Tree with MP3 (lame) support ***
Install the dependencies required to build and use ffmpeg:
Now install the FreeBSD Ports Tree
Build ffmpeg
Navigate to the ffmpeg port directory
Configure ffmpeg build
This will bring up a menu. Scroll down using arrow keys to “LAME” and hit the spacebar to enable it. Press enter to continue.
The ffmpeg source files will automatically be downloaded then you will be presented with an additional prompt to install documentation. I uncheck with spacebar then press enter to continue.
Start build and installation of ffmpeg
Building ffmpeg will take some time depending on the capabilities of your machine, please be patient.
Symlink ffmpeg to where Airsonic expects the transcoder to be.
*** Test airsonic (command line start) ***
*** Create rc autostart script ***
*** Navigate to Airsonic in a browser ***
Default context and port (command line test start):
Configured context and port (automatic service start):
*** Path to update spanish translate ***
document:
New translation web:
**** Content of airsonic rc script file (/etc/rc.d/airsonic) ***
/etc/rc.d/airsonic
Regards
FreeNAS-11.2-BETA1
iocage create --name "airsonic" --release 11.1-RELEASE boot=on vnet=on ip4_addr="vnet0|192.168.1.217/24" defaultrouter="192.168.1.1" host_hostname="airsonic" allow_raw_sockets="1"
*** Add storage ***
iocage fstab --add airsonic /mnt/tank/media/Music /media nullfs rw 0 0
#iocage start airsonic
#iocage stop airsonic
#iocage set boot=off airsonic
#iocage set ip4_addr="vnet0|192.168.1.217/24" airsonic
#setenv EDITOR /usr/local/bin/nano
#iocage fstab -e airsonic
iocage console airsonic
pkg update
pkg upgrade
pkg install nano wget
pkg install java/openjdk8
mkdir /var/airsonic/
mkdir /usr/local/airsonic
cd /usr/local/airsonic
wget https://github.com/airsonic/airsonic/releases/download/v10.1.2/airsonic.war --no-check-certificate
exit
cp -Raf "/mnt/pool/jails/airsonic/var/airsonic" "/mnt/iocage/jails/airsonic/root/var" # database and config
cp "/mnt/pool/jails/airsonic/etc/rc.d/airsonic" "/mnt/iocage/jails/airsonic/root/etc/rc.d/" # rc script
chown -R ${USER}:${GROUP} /var/airsonic # root:wheel
pkg install yasm binutils texi2html frei0r v4l_compat gmake pkgconf perl5 fontconfig freetype2 opencv-core schroedinger libtheora libv4l libva libvdpau libvorbis libvpx libx264 xvid gnutls libiconv
portsnap fetch
portsnap extract
Build ffmpeg
cd /usr/ports/multimedia/ffmpeg
make configure
make install clean
ln -s /usr/local/bin/ffmpeg /var/airsonic/transcode/ffmpeg
#java -jar airsonic.war
/usr/local/bin/java -jar /usr/local/airsonic/airsonic.war
nano /etc/rc.d/airsonic # ...and paste text from the bottom
chmod +x /etc/rc.d/airsonic
sysrc "airsonic_enable=YES" # make service start at jail startup (changes /etc/rc.conf)
service airsonic start # start service
service airsonic stop
netstat -an | grep 8080 # Check if listening at port 8080
cat -v airsonic # Check if script file have any CR at line end (shows: ^M)
tr -d '\r' < infile > outfile # Eliminate CRs
airsonic.war\WEB-INF\classes\org\airsonic\player\i18n\ResourceBundle_es.properties
document:
Old translation web:New translation web:
/etc/rc.d/airsonic
#!/bin/sh
# $FreeBSD: airsonic $
# PROVIDE: airsonic REQUIRE: LOGIN KEYWORD: shutdown
# Configuration settings for airsonic in /etc/rc.conf:
# airsonic_enable (bool):
# Set to "NO" by default. Set it to "YES" to enable airsonic.
# airsonic_home (str):
# Set to "/var/airsonic" by default.
# airsonic_host (str):
# Set to "0.0.0.0" by default. Specify which IP address to listen to.
# airsonic_port (int):
# Set to "4040" by default. Specify which port to listen on for HTTP(S).
# airsonic_context_path (str):
# Set to "/" by default. Specify the last part of the airsonic URL, typically "/" or "/airsonic".
# airsonic_init_memory (int):
# Set to "192" by default. Specify the memory initial size (Java heap size) in megabytes.
# airsonic_max_memory (int):
# Set to "384" by default. Specify the memory limit (Java heap size) in megabytes.
. /etc/rc.subr
name=airsonic
desc="Airsonic is a free, web-based media streamer, providing ubiquitous access to your music"
rcvar=${name}_enable
pidfile="/var/run/${name}.pid"
load_rc_config "${name}"
: ${airsonic_enable:="NO"}
: ${airsonic_user:="root"} #: ${airsonic_user:="media"}
: ${airsonic_group:="wheel"} #: ${airsonic_group:="media"}
: ${airsonic_home:="/var/airsonic"}
: ${airsonic_address:="0.0.0.0"}
: ${airsonic_port:="4040"}
: ${airsonic_ssl:="NO"}
: ${airsonic_context_path:="/airsonic"}
: ${airsonic_init_memory:="192"}
: ${airsonic_max_memory:="512"}
: ${airsonic_chdir:="/usr/local/airsonic"}
start_cmd=airsonic_start
stop_cmd=airsonic_stop
restart_cmd=airsonic_restart
status_cmd=airsonic_status
start_precmd="export LC_CTYPE='en_US.UTF-8'"
# -Dairsonic.defaultMusicFolder=${airsonic_home}/artists \
# -Dairsonic.defaultUploadFolder=${airsonic_home}/incoming \
# -Dairsonic.defaultPodcastFolder=${airsonic_home}/podcasts \
# -Dairsonic.defaultPlaylistImportFolder=${airsonic_home}/playlists/import \
# -Dairsonic.defaultPlaylistExportFolder=${airsonic_home}/playlists/export \
# -Dairsonic.defaultPlaylistBackupFolder=${airsonic_home}/playlists/backup \
command="/usr/sbin/daemon -p ${pidfile} -f -u ${airsonic_user}"
procname="/usr/local/bin/java"
command_args="-Dairsonic.home=${airsonic_home} -Dserver.address=${airsonic_address} -Dserver.port=${airsonic_port} -Dserver.context-path=${airsonic_context_path} -Xms${airsonic_init_memory}m -Xmx${airsonic_max_memory}m -Djava.awt.headless=true -jar ${airsonic_chdir}/airsonic.war"
command_args1="-Dairsonic.home=${airsonic_home} -Dserver.port=${airsonic_port} -jar ${airsonic_chdir}/airsonic.war"
airsonic_start() {
echo "Starting Airsonic"
echo "${command} ${procname} ${command_args}"
cd ${airsonic_chdir}
airsonic_stop() {
echo "Stopping Airsonic"
kill `cat ${pidfile}`
rm ${pidfile}
airsonic_restart() {
airsonic_stop
sleep 1
airsonic_start
airsonic_status() {
if airsonic_check; then
echo "Airsonic running"
return 1
else
echo "Airsonic not running"
return 0
fi
airsonic_check() {
if [ -f ${pidfile} ]; then
return 0
else
return 1
fi
run_rc_command "$1"
Regards
