I'm sure I'm not alone when I say the 1st thing I do when i login to the GUI is look at the (hopefully) green Status in the top right. More often than not I'll login to one of the NAS's just to check-up on it's status.
I just wondered if there was a command, script or API that could return the colour of the light? I quite simply want to look at the possibilities of an RGB LED mounted on the NAS boxes so that at a glance I can see it's status. Once I find a way of getting this data I think I could do the reset, possibly controlled by an ardunio nano board or the like, through the serial interface or via network.
any feedback will be appreciated.
