SOLVED FolderSync Android App Issue with Path
a7691
I have FolderSync app installed on my android phone and have been attempting to connect it to the SMB share on TrueNas, but I keep getting error message stating "STATUS_BAD_NETWORK_NAME." The server address is correct and in the SMB share name field I have my path as:
Network_HDD/Smartphone Backups/motoX4
This path works perfectly if I access from Windows Explorer on my Desktop PC, but not so in FolderSync. Anyone know how I should set the pathing information in FolderSync app?
a7691
The solution turned out to be that you don't give the path information, just the name of the SMB share. You can then choose the folder when creating a folder pair in FolderSync.
