I am running nfsv4 but without LDAP or ActiveDirectory. Just standard NFSv4 Kerberos mapping with my own local KDCs. I need Domain set to my domain name in /etc/idmapd.conf in order for the mapping/permissions to work on TrueNAS Scale but any change I make manually is lost over an update or even a power cycle.
I've seen other threads on this, but no resolutions posted. In my own investigations I've found that the middleware will set Domain in /etc/idmapd.conf to a config setting called "v4_domain". I can identify nothing that looks like that in the TrueNAS Scale UI however. Where is this v4_domain config setting coming from in the UI. Or if not in the UI yet is there a means for me to set it so my domain in idmapd.conf is preserved?
Thanks!
Thanks!
