this is a small tutorial on how to get a vgpu in a virtual machine. This is useful if, for example, you want to have a VM for Docker and run hardware transcoding there, or if you want graphics accelerated Windows.
This guide was tested on TrueNAS SCALE 22.12.4, in future versions this method may not work. Keep in mind, this guide uses GVT-g, so this only works with Intel Broadwell (5th gen) to Comet Lake (10th gen).
1. Access the Shell
2. run
3. run
4. run
5. Reboot the System
6. Access the Shell again
7. run
8. run
9. find out id/path from the graphics card, in my case
10. Look which types are supported by your gpu, with
10.1. In my Case with an I5-6600 its
10.2. See what fits best for the use case, you can see what the individual modes can do with
11. Generate a uuid or just use this one
12. Create a vgpu
13. run
14. Now search for the VM ID with,
15. Edit the XML with
15.1. Paste the following (abbove the last two lines)
16. Now run the VM with
Important Note
Only start via the command above, otherwise TrueNAS will overwrite the config, also disable autostart for the vm. Exit the vm via the UI does not change the config.
Not all changes are permanent, so here is a very simple script that sets all the required things and starts the VM when TrueNAS starts. Adapt it to your needs
Store this in a dataset that is not encrypted or automatically decrypted at boot time.
Make this runnable with
Under
Relevant sources
https://wiki.archlinux.org/title/Intel_GVT-g
https://www.truenas.com/community/threads/21-02-alpha-1-virsh-commands-fail.91229/post-636109
1. Access the Shell
2. run
$ cli3. run
> system advanced update kernel_extra_options="i915.enable_gvt=1 i915.enable_guc=0"4. run
> exit5. Reboot the System
7. run
$ sudo su -8. run
# modprobe kvmgt mdev vfio-iommu-type19. find out id/path from the graphics card, in my case
0000:00:02.0, you can use lspci -D -nn10. Look which types are supported by your gpu, with
# ls /sys/devices/pci0000:00/0000:00:02.0/mdev_supported_types10.1. In my Case with an I5-6600 its
i915-GVTg_V5_4 and i915-GVTg_V5_810.2. See what fits best for the use case, you can see what the individual modes can do with
# cat /sys/devices/pci0000:00/0000:00:02.0/mdev_supported_types/i915-GVTg_V5_4/description (A lower number is better, because they have a higher resolution, more memory and more performance)11. Generate a uuid or just use this one
37d7d57d-de7b-47e0-ae05-d6e69b98d62912. Create a vgpu
# echo "37d7d57d-de7b-47e0-ae05-d6e69b98d629" > "/sys/devices/pci0000:00/0000:00:02.0/mdev_supported_types/i915-GVTg_V5_4/create"13. run
# ln -s /run/truenas_libvirt/libvirt-sock /var/run/libvirt/libvirt-sock14. Now search for the VM ID with,
# virsh list15. Edit the XML with
# virsh edit 1_my_vm15.1. Paste the following (abbove the last two lines)
<hostdev mode='subsystem' type='mdev' managed='no' model='vfio-pci' display='off'>
<source>
<address uuid='af86b65f-13a3-4c17-a0f3-2b2b3aa573f9'/>
</source>
</hostdev>
# virsh start 1_my_vmImportant Note
#!/bin/zsh modprobe kvmgt mdev vfio-iommu-type1 ln -s /run/truenas_libvirt/libvirt-sock /var/run/libvirt/libvirt-sock echo "37d7d57d-de7b-47e0-ae05-d6e69b98d629" > "/sys/devices/pci0000:00/0000:00:02.0/mdev_supported_types/i915-GVTg_V5_4/create" virsh start 1_my_vm
# chmod u+x myscript.shUnder
System Settings -> Advanced -> Init/Shutdown Scripts you can choose the script and run at Post InitRelevant sources
