I tried cloning a jail this morning however received this error regarding the length to be more than 63 characters:
report_problem ValidationErrors
[ENAMETOOLONG] vm_create.devices.1.attributes.path: Disk path /dev/zvol/tank/VM/Arch/ArchZFSProxy/ArchZFSProxy-62jq1i_ArchZFSBW is too long, reduce to less than 63 characters
This was middleware error report:
Whats the deal with the 63 character limit? Why is that a limitation?
In addition the cloning function isn't working as I would expect.
The dataset I'm trying to clone is:
Please note that the GUI when I created this VM tacked on the -62jq1i lettering -- I have no idea where this came from.
When I selected clone - it said enter clone name and I enter ArchZFSBW. This resulted in the GUI creating:
when I would have it expected it to be:
/dev/zvol/tank/VM/Arch/ArchZFSProxy/ArchZFSBW
I understand I can probably do all this manually, however GUI functionality is nice -- however in this case I don't think the implementation is correct.
Error: Traceback (most recent call last): File "/usr/local/lib/python3.7/site-packages/middlewared/main.py", line 130, in call_method io_thread=False) File "/usr/local/lib/python3.7/site-packages/middlewared/main.py", line 1077, in _call return await methodobj(*args) File "/usr/local/lib/python3.7/site-packages/middlewared/schema.py", line 960, in nf return await f(*args, **kwargs) File "/usr/local/lib/python3.7/site-packages/middlewared/plugins/vm.py", line 1170, in clone raise e File "/usr/local/lib/python3.7/site-packages/middlewared/plugins/vm.py", line 1153, in clone await self.create(vm) File "/usr/local/lib/python3.7/site-packages/middlewared/service.py", line 396, in create f'{self._config.namespace}.create', self, self.do_create, [data] File "/usr/local/lib/python3.7/site-packages/middlewared/main.py", line 1077, in _call return await methodobj(*args) File "/usr/local/lib/python3.7/site-packages/middlewared/schema.py", line 960, in nf return await f(*args, **kwargs) File "/usr/local/lib/python3.7/site-packages/middlewared/plugins/vm.py", line 804, in do_create verrors.check() File "/usr/local/lib/python3.7/site-packages/middlewared/service_exception.py", line 62, in check raise self middlewared.service_exception.ValidationErrors: [ENAMETOOLONG] vm_create.devices.1.attributes.path: Disk path /dev/zvol/tank/VM/Arch/ArchZFSProxy/ArchZFSProxy-62jq1i_ArchZFSBW is too long, reduce to less than 63 characters
