hellomynameisleo
 - Mar 11, 2023
I am currently using a dataset on my truenas connected over SMB to a single pc. I found out about using zvols to create a iscsi instead to mount directly to windows and it would give better performance.
If checksum errors was to be detected on the zvol would trueNas know what files has been corrupted? I ask this because truenas will see the zvol as a virtual drive as a whole and not see the individual files like it would do on a dataset and this matters because I'm running trueNAS on stripped vdevs and would prefer to replace the corrupted files from a backup.
Also is there a way to allocate 100% space to a zvol when creating one? I only see an option for inputting the amount of gb/tb manually.
