brownj
- Nov 2, 2019
In the status listing below , what is:
4162934543819156499 UNAVAIL 0 0 0 was /dev/sde
can i "zpool detach data-pool 4162934543819156499". what is this exactly ???. it resulted from changing a drive out
I have tried detaching ( all error out with cant detach a root lovel vdev) , can;t replace it , what to do ?
zpool status data-pool -P
pool: data-pool
state: DEGRADED
status: One or more devices could not be used because the label is missing or
invalid. Sufficient replicas exist for the pool to continue
functioning in a degraded state.
action: Replace the device using 'zpool replace'.
see: https://openzfs.github.io/openzfs-docs/msg/ZFS-8000-4J
scan: scrub repaired 0B in 02:22:57 with 0 errors on Fri Oct 7 14:17:43 2022
NAME STATE READ WRITE CKSUM
data-pool DEGRADED 0 0 0
raidz1-0 DEGRADED 0 0 0
spare-0 DEGRADED 0 0 0
/dev/disk/by-partuuid/c67c4bdc-91dc-4c14-8f34-15504a4c0f57 ONLINE 0 0 0
/dev/disk/by-partuuid/71800691-a44f-41e2-b5db-a04c6b3eb0c4 ONLINE 0 0 0
/dev/disk/by-partuuid/1ea5da57-9e44-11eb-bf24-2cf05da31333 ONLINE 0 0 0
spares
/dev/sde FAULTED corrupted data
