Zoneminder on FreeNAS
melloa
Version 1.01 - Added pkg install option.
  • Zoneminder FreeBSD installation 1.01.pdf
SinDeus
I followed your guide from beginning to end, great job!
Two little tweaks I had to do though:
  • During the pkg install phase, I had to run the command twice: it stopped the first time after having installed some packages, re-running it completed the installation.
  • With my version of PHP (or PHP-FPM, I don't really know), I had to update the file located at /usr/local/etc/php-fpm.d/www.conf instead of php-fpm.conf.
melloa
Funny ... I did run the pkg install with all and only required one pass to install all.
[LIST said:
[*]With my version of PHP (or PHP-FPM, I don't really know), I had to update the file located at /usr/local/etc/php-fpm.d/www.conf instead of php-fpm.conf.
[/LIST]
No ideas. I updated with pkg update and run the install with pkg. I didn't have time to finish the configuration and test to see if runs. A little out of time with work catching fire ;)
Cesaric
@Joshua Parker Ruehlig
Minor note; I'm going through this setup now with PHP7.0 and the config is in the php-fpm.d folder and not php-conf.d.
root@zoneminder:/usr/local/etc/php-fpm.d # cat -n www.conf
1 ; Start a new pool named 'www'.
2 ; the variable $pool can we used in any directive and will be replaced by the
35 ; Note: This value is mandatory.
36 listen = 127.0.0.1:9000
melloa
Thanks @Cesaric. Any other changes please let me know so I can update the guide. I didn't have time to go through it with the new php version and as per your comment directories have changed ...
Cesaric
Will do... so far, you have "Americas/New_York" on your screenshot in your manual (you have it right in the description). Just need to drop the "s" on America.
Cesaric
@melloa do you mind attaching your nginx.conf file? I'm getting odd formatting when I copy and paste it from the "...1.01.pdf".
melloa
Copied from the DOC, please let me know if won't work.
  • nginx config.txt
Cesaric
I ended up formatting manually but comparing side-by-side the my.cnf's are nearly identical.
I just finished up the instructions and got the zoneminder page to come right up in my browser. Nice work and thank you for putting that together!!!
melloa
Great you got it working. Will make the changes you've identified.
melloa
Question:
The config been changed is still on the same folder:
root@test1:/usr/local/etc # find / -name php-fpm.conf
/usr/local/etc/php-fpm.conf
What exactly have you changed in the flow?
Yes, www.conf is found on:
root@test1:/usr/local/etc/php-fpm.d # ll
total 38
-rw-r--r-- 1 root wheel 18494 Jun 4 23:57 www.conf
-rw-r--r-- 1 root wheel 18494 Jun 4 23:57 www.conf.default
But the original instructions from github README made no changes to it. Are we saying now it needs to be changed instead of php-fpm.conf?
Thanks!
Cesaric
Question:
total 38
Thanks!
I believe the FPM config has been split up into two files (php-fpm.conf and www.conf) for PHP7.0 if I remember correctly. They literally just moved everything after something like line ~30 in php-fpm.conf into www.conf.
melloa
hmmm ... OK ... will need to duplicate to capture all changes. Thanks for the heads-up.
yup, I new that was the folder name, but obviously typed it wrong. I'll fix my post
melloa
@Joshua Parker Ruehlig @Cesaric
Just went through the steps installing with
pkg install zoneminder nginx mysql56-server php70-pdo_mysql php70-gd fcgiwrap php70-
session
and didn't have to make any changes on any config file name or location. Zoneminder started and runs fine:
Thoughts?
  • Zoneminder FreeBSD installation 1.02.pdf
session
Thoughts?
not sure what you are asking, but we did integrate some fixes into the port (which may be built for pkg by now) last week.
https://github.com/freebsd/freebsd-ports/commit/8d5ce6a1bc7f1ce090c35dfb5472274281bb4bd8
You might not even need to specify 'php70-pdo_mysql php70-gd php70-session' anymore.
melloa
Great, thanks for committing the fixes.
What I'm referring to is the post above that @Cesaric mentioned there was a "new" configuration file: "Minor note; I'm going through this setup now with PHP7.0 and the config is in the php-fpm.d folder and not php-conf.d."
I did install with php 7.0 and zonemider worked without any changes to my install steps, so trying to confirm to update the guide.
Ok, I will test that.
ahh, if this is a fresh jail/VM then it should be in the php-fpm.d folder.
If not, then since you edited your php-fpm.conf, it wouldn't have been deleted, so your still using an older style config that does include the php-fpm.d folder.
Marcet
Very interesting thread. I'm currently experimenting ZoneMinder 1.29.0 in a VirtualBox CentOS VM hosted on my FreeNAS System.
I'll migrate to a Jail as soon as I feel more confortable with it.
Any chance to see a plugin one day ?
