Zonemaster Plugin Post Install Activites?
jmacwill
Hi everyone - after having caused strict search in and about the various corners of the internet - I come here, hat in hand, asking for help.
I have just installed the zonemaster plugin , version 1.36.12, on my TrueNas Core setup.
When I try to access it via the web I get the following error:
I have read somewhere that there are some post installation activites that need to happen after the plugin is installed, but there is nothing clear.
Has anyone shared my experience and found a way around it? If so, I am happy to write-up a guide so we can post it here.
Thanks in advance!
Jonathan MacWilliams
TrueNAS Core
AMD A10
16gb ram
3x4tb drives - 7tb usable
jmacwill
Update:
I found a file that detailed the configuration activities for Zoneminder on a TRUENas setup. I started doing those activities, of which most had been completed.
In the end, I broke the install and it would not even take me to the error page above.
So, I started over - I nuked the install, and tried again.
The second time through, the install took much longer and downloaded more items and left me with a much larger post install log file.
Interestingly enough, this install works!
I did nothing different - I did not reboot, I did not update - it just worked.....
Anyway - for those who read this, thanks for reading! If yours does not work the first time, nuke it and try it again, it may just work.
