I have a backup script that automatically mounts a single vdev (disk) pool. To do this, it is dependent upon zpool import having a gptid for the device. I was careless and did not properly unmount a backup pool, and something happend to the gptid.
Before improper unmount:
After improper mount:
I have checked that this has nothing to do with the pool not being upgraded. I have another backup pool that was created in exactly the same way but was not improperly handled, and it is still displaying a gptid.
glabel status still shows the gptid:
and zfs list shows the pool name correctly and all the snapshots.
If I manually mount the pool from the command line using
How can I fix this? (I'm OK with changing to a different gptid if necessary.) I would just rather not have to run the backup again since it contains about 8TB of data and is going to take some time. (Iit will also require a current pool, and I'm not ready to commint to 11.2-U7 just yet.)
#>zpool import
pool: BACKUP02
state: ONLINE
action: The pool can be imported using its name or numeric identifier.
BACKUP02 ONLINE
gptid/735dxxxx-xxxx-xxxx-xxxx-xxxx17d2xxxx ONLINEAfter improper mount:
#>zpool import
pool: BACKUP02
state: ONLINE
status: Some supported features are not enabled on the pool.
action: The pool can be imported using its name or numeric identifier, though
some features will not be available without an explicit 'zpool upgrade'.
BACKUP02 ONLINE
ada3p2 ONLINEI have checked that this has nothing to do with the pool not being upgraded. I have another backup pool that was created in exactly the same way but was not improperly handled, and it is still displaying a gptid.
Name Status Components gptid/735dxxxx-xxxx-xxxx-xxxx-xxxx17d2xxxx N/A ada3p2
zpool import BACKUP02, I can still access the data, so other than the gptid not showing up correctly in the import command (and also zpool status when mounted), everything is OK.How can I fix this? (I'm OK with changing to a different gptid if necessary.) I would just rather not have to run the backup again since it contains about 8TB of data and is going to take some time. (Iit will also require a current pool, and I'm not ready to commint to 11.2-U7 just yet.)
