Had a power failure (UPS didn't catch it unfortunately) and logged into the web interface to this error message:
For the sake of it my understanding is it should've brought the replacement online and marked the offline drive as the replacement (IE: Go get a new drive asap), is this operating "as intended" or is there something more wrong with it? Yes, there's a scrub running atm.
zpool clear did nothing, so I assume it's an ongoing error.
My key questions are: Why did my second drive rename itself suddenly to 89192...etc? And how do I figure out which drive this physcially is inside the box so I can manually check (and/or replace) it?
Also, every 8 minutes my server runs at 100% cpu load for 2 minutes then stops for another 8 minutes producing load averages of about 1.2 on a dual core machine. Should I be concerned or is it related to the downed drive?
- WARNING: The volume RaidBackup (ZFS) status is UNKNOWN: One or more devices could not be opened. Sufficient replicas exist for the pool to continue functioning in a degraded state.Attach the missing device and online it using 'zpool online'.
zpool status RaidBackup pool: RaidBackup state: DEGRADED status: One or more devices could not be opened. Sufficient replicas exist for the pool to continue functioning in a degraded state. action: Attach the missing device and online it using 'zpool online'. see: http://www.sun.com/msg/ZFS-8000-2Q scan: scrub in progress since Thu Jul 4 20:55:42 2013 334G scanned out of 2.04T at 287M/s, 1h44m to go 0 repaired, 15.97% done config: NAME STATE READ WRITE CKSUM RaidBackup DEGRADED 0 0 0 raidz1-0 DEGRADED 0 0 0 gptid/148b5fc8-38fd-11e2-b72a-3cd92b06d364 ONLINE 0 0 0 8919218218043267245 UNAVAIL 0 0 0 was /dev/gptid/15072f46-38fd-11e2-b72a-3cd92b06d364 gptid/15813846-38fd-11e2-b72a-3cd92b06d364 ONLINE 0 0 0 spares gptid/160324c3-38fd-11e2-b72a-3cd92b06d364 AVAIL errors: No known data errors
