ZFS Drive Size and Cost Comparison Spreadsheet to find best $/TiB
ZFS Drive Size and Cost Comparison Spreadsheet to find best $/TiB 1.2
diedrichg
diedrichg submitted a new resource:
ZFS Drive Size and Cost Comparison Spreadsheet to find best $/TiB - Compare 1:1 the potential size of your pool to find the most cost-effective $/TiB option
Hi all. I have created a shared Google spreadsheet to supplement @Bidule0hm 's ZFS RAID Size Calculator. The purpose of the spreadsheet is to compare 1:1 the potential size of your pool if you are planning RAIDZ1 or RAIDZ2 (for example). You can then edit the top portion of the spreadsheet to figure the most cost-effective ($/TiB) option for your build.
I used...
Read more about this resource...
ZPrime
@diedrichg Any chance of getting the sheet (or at least the Google / online version) updated with larger HDD capacities? I think I can see what you have going on down in the tables and with the hidden formula cells, but it seems non-trivial to update all of those formula cells with an expanded lookup range after adding more columns for 16 & 18TB...
diedrichg
Google Sheets version is updated. I'll work on the Excel version as soon as I can get to it.
