I started receiving emails about a device fault, which happens. This particular pool was a simple 2 disk mirror, thankfully not one of the larger pools, which could take forever to resilver. Anyhow I have hot spares, so back up and running.
I was going to open a warrantee claim with the HD vendor and figured I should rerun the long smart test and badblocks to make sure the fault was well documented, but both came back negative for any issues.
What is it that TrueNAS Scale has identified? Every other drive failure I've ever experienced is pretty cut and dry. Now I haven't powered off/pulled this drive, so it hasn't stopped spinning, maybe it won't fire back up? I'm almost considering putting it back in service, but don't want to put anything at risk if this has already been identified as a failed drive. I just have NO idea what to provide to the HD vendor at this point?
TrueNAS-SCALE-22.12.2
Supermicro: X12SPI-TF
Memory: 256GB ECC
CPU: Intel(R) Xeon(R) Gold 6326
Degraded:
Faulted:
Scrub:
Another Fault Email:
Smart Results:
Memory: 256GB ECC
Degraded:
Pool POOLNAME state is DEGRADED: One or more devices are faulted in response to persistent errors. Sufficient replicas exist for the pool to continue functioning in a degraded state. The following devices are not healthy: Disk ST16000NM001G-2KK103 ZL55AAAA is FAULTED
Faulted:
The number of I/O errors associated with a ZFS device exceeded acceptable levels. ZFS has marked the device as faulted. impact: Fault tolerance of the pool may be compromised. eid: 6392 class: statechange state: FAULTED host: truenas time: 2023-05-21 00:12:30-0700 vpath: /dev/disk/by-partuuid/5760c266-157a-4ed6-87a2-f1f2fd4a05f1 vguid: 0x5E1A4E3A423A14D5 pool: POOLNAME
Scrub:
ZFS has finished a scrub: eid: 6471 class: scrub_finish host: truenas time: 2023-05-21 14:57:35-0700 pool: POOLNAME state: DEGRADED status: One or more devices are faulted in response to persistent errors. Sufficient replicas exist for the pool to continue functioning in a degraded state. action: Replace the faulted device, or use 'zpool clear' to mark the device repaired. scan: scrub repaired 12M in 14:57:33 with 0 errors on Sun May 21 14:57:35 2023 config: NAME STATE READ WRITE CKSUM POOLNAME DEGRADED 0 0 0 mirror-0 DEGRADED 0 0 0 25047394-01d4-49ce-985a-9f893d7772de ONLINE 0 0 0 5760c266-157a-4ed6-87a2-f1f2fd4a05f1 FAULTED 19 0 89 too many errors errors: No known data errors
The number of I/O errors associated with a ZFS device exceeded acceptable levels. ZFS has marked the device as faulted. impact: Fault tolerance of the pool may be compromised. eid: 6582 class: statechange state: FAULTED host: truenas time: 2023-05-22 09:12:10-0700 vpath: /dev/disk/by-partuuid/5760c266-157a-4ed6-87a2-f1f2fd4a05f1 vguid: 0x5E1A4E3A423A14D5 pool: POOLNAME
Smart Results:
smartctl -a /dev/sdh
smartctl 7.2 2020-12-30 r5155 [x86_64-linux-5.15.79+truenas] (local build)
Model Family: Seagate Exos X16
Device Model: ST16000NM001G-2KK103
Serial Number: ZL55AAAA
LU WWN Device Id: 5 000c50 0c64f3d95
Firmware Version: SN03
User Capacity: 16,000,900,661,248 bytes [16.0 TB]
Rotation Rate: 7200 rpm
Form Factor: 3.5 inches
ATA Version is: ACS-4 (minor revision not indicated)
SATA Version is: SATA 3.3, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is: Mon May 22 09:07:21 2023 PDT
SMART support is: Enabled
General SMART Values:
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
been run.
data collection: ( 567) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: (1423) minutes.
Conveyance self-test routine
SCT capabilities: (0x70bd) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x000f 072 064 044 Pre-fail Always - 15321160
3 Spin_Up_Time 0x0003 089 089 000 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 21
5 Reallocated_Sector_Ct 0x0033 100 100 010 Pre-fail Always - 0
7 Seek_Error_Rate 0x000f 089 060 045 Pre-fail Always - 717575071
9 Power_On_Hours 0x0032 074 074 000 Old_age Always - 22896
10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 21
18 Head_Health 0x000b 100 100 050 Pre-fail Always - 0
187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0
188 Command_Timeout 0x0032 100 100 000 Old_age Always - 0
190 Airflow_Temperature_Cel 0x0022 068 053 040 Old_age Always - 32 (Min/Max 26/38)
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 1
193 Load_Cycle_Count 0x0032 071 071 000 Old_age Always - 59749
194 Temperature_Celsius 0x0022 032 047 000 Old_age Always - 32 (0 21 0 0 0)
197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 4
200 Pressure_Limit 0x0023 100 100 001 Pre-fail Always - 0
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 18253h+16m+15.441s
241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 147471182375
242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 519560064407
SMART Error Log Version: 1
No Errors Logged
# 1 Extended offline Completed without error 00% 22892 -
# 2 Short offline Completed without error 00% 22871 -
# 3 Short offline Completed without error 00% 22864 -
# 4 Short offline Completed without error 00% 22840 -
# 5 Short offline Completed without error 00% 22816 -
# 6 Short offline Completed without error 00% 22792 -
# 7 Short offline Completed without error 00% 22768 -
# 8 Short offline Completed without error 00% 22744 -
# 9 Short offline Completed without error 00% 22720 -
#10 Short offline Completed without error 00% 22696 -
#11 Short offline Completed without error 00% 22672 -
#12 Short offline Completed without error 00% 22648 -
#13 Short offline Completed without error 00% 22624 -
#14 Short offline Completed without error 00% 22600 -
#15 Short offline Completed without error 00% 22576 -
#16 Short offline Completed without error 00% 22552 -
#17 Short offline Completed without error 00% 22528 -
#18 Short offline Completed without error 00% 22504 -
#19 Short offline Completed without error 00% 22480 -
#20 Short offline Completed without error 00% 22456 -
#21 Short offline Completed without error 00% 22432 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
