Good morning~
I have built and maintained a FreeNAS box at home for a few years now, dating back to 10.0 I think it was. Never had an issue until I recently upgraded to TrueNAS13.0. Now, this may or may not be the crux of the issue, so let me give a few more details.
My server is built from parts of older PCs we grew out of, currently using 12G ram and a 4-disk (WD Red 3TBs) ZFS2 array. Previously it was a ZFS1 but I had to rebuild after it suddenly reported corruption. The drives had no SMART errors. Upon reboot, the array would no longer mount. I had to rescue-mount is as RO to export the data I was still able to reach and rebuild. Here's some of my notes in case they may help someone in the same situation:
That last file is commonly (?) corrupted
Reddit
www.reddit.com
potential fix:
And while I was looking for that sqlite command (`find /Plex\ Media\ Server -iname "*sqlite*"`), it started an endless and unprompted reboot loop, kernel panic when loading storage pool.
I found a thread that referred to 'many threads' where the outcome was to nuke the pool and restart from scratch, another thread mentioning how ZFS relies heavily on RAM and if that goes bad it may bring down the array with it - I'll run a memcheck and find out.
The article listed above,
openzfs.github.io
mentions the only outcome is to restore the pool from backup.
Mounting the storage pool RO for recovery:
Since the drives themselves had no errors, I thought reusing them was fine but the same error came up again:
We're now on track to replace the drives and rebuild yet again, but I wanted to know what exactly is that `root:<0x27795>` file, it was the first file to report corruption in both iterations.
I would be very interested in finding the root cause of this or if someone else encountered this, be it drives, ZFS, lack of resources, bad cables.
Thanks for reading,
Ben
root@underdesk[~]# zpool status -v
pool: freenas-boot
state: ONLINE
scan: scrub repaired 0B in 00:07:59 with 0 errors on Tue Jun 28 03:53:00 2022
NAME STATE READ WRITE CKSUM
freenas-boot ONLINE 0 0 0
ada0p2 ONLINE 0 0 0
errors: No known data errors
pool: storage
state: DEGRADED
corruption. Applications may be affected.
action: Restore the file in question if possible. Otherwise restore the
entire pool from backup.
see: https://openzfs.github.io/openzfs-docs/msg/ZFS-8000-8A
scan: scrub repaired 0B in 09:40:27 with 0 errors on Sun Jun 12 09:40:27 2022
storage DEGRADED 0 0 0
raidz1-0 DEGRADED 0 0 0
gptid/1cb77a81-da22-11e9-a666-002618a144fb DEGRADED 0 0 1.18K too many errors
gptid/1e6b6db5-da22-11e9-a666-002618a144fb DEGRADED 0 0 1.18K too many errors
gptid/1f351d58-da22-11e9-a666-002618a144fb DEGRADED 0 0 1.18K too many errors
gptid/255219dc-d469-11ec-900c-60a44c57a05a DEGRADED 0 0 1.18K too many errors
storage/iocage/jails/plexmediaserver/root:<0x0>
/mnt/storage/iocage/jails/plexmediaserver/root/Plex Media Server/Plug-in Support/Databases/com.plexapp.plugins.library.db
$ "/usr/lib/plexmediaserver/Plex SQLite" "/var/lib/plex/Plex Media Server/Plug-in Support/Databases/com.plexapp.plugins.library.db" ".recover" | "/usr/lib/plexmediaserver/Plex SQLite" fix.db
$ "/usr/lib/plexmediaserver/Plex SQLite" fix.db "PRAGMA integrity_check"
Message ID: ZFS-8000-8A — OpenZFS documentation
rebooted
option 3? boot options or something
> set vfs.zfs.recover=1
> set vfs.zfs.debug=1
> boot -s
(enter for shell)
> zdb -e -bcsvL storage
> zfs set readonly=off freenas-boot
> zfs mount -a
this got me a readonly storage pool
now need to get the data off if possible
tried an ip address
> ifconfig re0 192.168.1.54
root@truenas[~]# zpool status -xv
pool: storage
state: ONLINE
storage ONLINE 0 0 0
raidz2-0 ONLINE 0 0 0
gptid/c07fb6d0-fb04-11ec-b551-60a44c57a05a ONLINE 0 0 0
gptid/c08a096c-fb04-11ec-b551-60a44c57a05a ONLINE 0 0 0
gptid/c091abba-fb04-11ec-b551-60a44c57a05a ONLINE 0 0 0
gptid/c0492aeb-fb04-11ec-b551-60a44c57a05a ONLINE 0 0 0
storage/iocage/jails/plex_server/root:<0x27795>
root@truenas[~]#
Thanks for reading,
Ben
