Yellow light is still blinking
bravo444
Hi, All,
I upgrade from 8.0.2 to 8.3 and I managed to fix the issue. However, I still have yellow light and message says
"The volume DATA (ZFS) status is UNKNOWN: The pool is formatted using an older on-disk format. The pool can still be used, but some features are unavailable.Upgrade the pool using 'zpool upgrade'. Once this is done, the pool will no longer be accessible on older software versions."
I did zpool upgrade command on shell and I restarted the system, but I still have the same message...
How can I fix this issue? Please let me know.
"[root@freenas ~]# zpool upgrade
This system is currently running ZFS pool version 28.
The following pools are out of date, and can be upgraded. After being
upgraded, these pools will no longer be accessible by older software versions.
VER POOL
15 DATA
Use 'zpool upgrade -v' for a list of available versions and their associated
features.
Thanks & regards,
bravo444
Hi, All,
Sorry, I fixed the issue. I did following command.
zpool upgrade DATA
Then, I don't see yellow light...
Sorry to bother you...
joeschmuck
Old Man
So all is good again? Make sure you save your configuration data once you have a chance.
JaimieV
Thumbs up! This is mentioned in the release notes for 8.3.0, by the way.
bravo444
Yes, everything is OK now :) Thanks for your support :)
Thanks & regards,
