- Jul 12, 2022
I built my own nas.
www.truenas.com
Plugged in everything, BMC Heartbeat led works as intended (blinks), but I can't seem to make the mobo power up. At the start I tried bridging the pins, then removed everything but the 8 and 24 PIN, CPU and CPU Cooler, still won't boot up.
Doing a bit of research I found an old post regarding an x10 mobo that had the exact same issue: it turned out that the BIOS of the MoBo didn't support the CPU.
www.truenas.com
Since I don't have any other processor that can fit the socket and I don't really want to do the thermal paste ritual, I wanted to update BIOS by IPMI, but before I buy the key (don0t actually know which version, but that's not the issue now), I wanted an opinion from you all.
My MoBo is Rev. 1.01, specs are in signature.
Please help, I am quite upset (mostly with myself).
SOLVED - Hardware Help (First Build)
Hello oh tech wizards, I want to build a little home NAS, nothing too serious but since it's my first NAS, I would like building it the right way. Initially I had choosen an Athleon 200G as my CPU, but grew concerned about ECC ram. It's really an hassle to understand compatibility, plus it...
SOLVED - X10SLL Won't Turn On
Hi guys, finally received my Supermicro X10SLL-F (after receiving a X10SLM+F with a bent serial port), built the whole system tonight, power led is on and heartbeat led is blinking, everything's looking good. I push the power button... nothing. Not a beep, no fans start spinning, absolutely dead...
