Will it freenas? i3-8100 Asus P11c_X
Ikarus123
I have read now alot about free nas and a few questios stayed unanswered. I want to build a freenas with around 15TB of storage for multimedia stuff. I picked some parts. I have now and old system with old hardware and a flexraid, with which i am not really satisfied.
My Ideas for parts is listed below.
I want to use my old 2TB random HDDs which are still functioning as a kind of backup. That means 4x4TB WD Red and a 6x2TB old HDD as backup in one case mirrored
Will this work in this constellation?
Thanks alot in advance
4x WD Digital Red 4TB Sata
https://www.amazon.de/WD-Red-4TB-in...ords=wd+red+4tb&qid=1566931615&s=ce-de&sr=1-1
Asus P11C-X
https://www.amazon.de/ASUS-P11C-X-Intel-Mehlow-90SB06Q0-M0UAY0/dp/B07KF686YX
i3-8100 with stock fan
https://www.amazon.de/Intel-i3-8100...eywords=i3+8100&qid=1566931631&s=ce-de&sr=1-1
SAMSUNG DIMM 16GB, DDR4-2666 ECC
https://www.e-tec.at/details.php?artnr=278899&hs=SAM
Fantec Case
https://www.amazon.de/FANTEC-1781-0-Storage-Gehäuse-schwarz/dp/B00VJM3DMA
Seasonic Power
https://www.e-tec.at/details.php?artnr=201301&hs=NON
Memory CRUCIAL MX500 250GB, M.2 (CT250MX500SSD4)
https://www.amazon.de/Crucial-MX500...X500+250GB,+M.2&qid=1566931865&s=ce-de&sr=1-1
unyi3lding
I have a similar question... looking to build a system using the same motherboard (but with the Mini-ITX version: [Newegg link]
Biggest question I'm struggling with: Does the C242 chipset only work with Coffee Lake and newer CPUs? (i3 8000 series and newer?) The specs list "Intel Core i3 processors; Intel Pentium processors; Intel Celeron processors " all in the supported CPU section, but doesn't make this distinction. I looked on the ASUS and Intel websites but the information is incomplete...
Thanks in advance!
