Th3ddy
- Aug 3, 2020
Hi, everyone,
I hope to find answers to my questions. Especially about the Raid part.
I have different HDDs for different uses and so ... The question is which Raid will be the most suitable... !?
Before making the listing, here is my hardware config:
Intel(R) Core(TM) i3 CPU 550 @ 3.20GHz
16GB of RAM
PCIe card 10 SATA 3 6GBps on 2x port
I have 2 HDDs of 10Tb each that I plan to put in RAID0 (STRIPPE).
Only storage for my movies.
No need for data protection.
Use for the PLEX server.
Do you see any suggestions? Any advice? ...
I have 8 HDDs of 6Tb each that I intend to use for my personal data and therefore with protection of them.
I will have a daily data backup to a SYNOLOGY DS918+ NAS with 16Tb in RAID SHR with a fault tolerance on 1 disk.
Questions and Answers :
Which RAID to use on FreeNAS ?
Standard Raid or Combined Raid ?
Fault tolerance on 1 or 2 disks ?
Do you see any suggestions ? Any advice ? .
I have 1 2Tb disk dedicated to plugins !
I have 1 SSD of 240 GB dedicated to the system!
This is a home NAS that will serve as my priority storage and it will be the cloud for my family members on the outside for their personal data.
In advance, thanks for your feedback ;) !
Th3ddy
16GB of RAM
Th3ddy
