Hi Profwalken,perhaps i found one, memory and MB are working together ?
Supermicro MBD-X11SCA-F-O maintenant 25% moins cher X11SCA-F Intel C246 LGA 1151
Supermicro X11SCA-F Intel C246 LGA 1151 (Emplacement H4) ATX remise 25%. MBD-X11SCA-F-O - Notre prix (HT) : 337,76 €. Uniquement chez nous !www.senetic.fr
A bit far from Paris, but there should be some store in the Sophia Antipolis area I would think.South east, Cannes
Not sure, i saw in user manual this
Does it means other MOBO than X11SCA-W have no thermal fan control, my actual bios has no thermal and fan menu.
Usually credential for IPMI refusal is due to capital vs lower case. Try all upper case, lower case combination for Admin and Password.I'm completely new on supermicro board , I found IPMI IP, but when i'm on credentials windows, tryed ADMIN as login and password with no luck
connection is refused wrong credentials, as it is only this i found as default login , so what can I do to be logged in ?
					www.gearprimer.com
				As far as I know, IPMI and BIOS are different entities.Do i need to set something in bios to be able to connect or is it default to be able to access ipmi?
All commands are from an installed OS have none
I tried to update Bios to new release but this is not working too, just followed this
when usb stick with is asked from the boot,with these files only
then just a reboot occurs
It seems you got stuck on 4-a.Do i need to set something in bios to be able to connect or is it default to be able to access ipmi?
Using Supermicro is an aquired taste.for a first contact with supermicro, it's not a piece of cake. Not so far to regrets to have bought one![]()
