which apc ups driver?
The UPS_HID one typically works well, IIRC.
andrewjs18
which one though? there's a ton of them.
I'm guessing maybe the APC ups 2 Smart-UPS USB USB (usbhid-ups)?
Try that one. If something's wrong, use the apcsmart one.
nick779
Thats what I use for my BR1000G and it works near flawlessly.
Strommen
Hi, uses the same(usbhid-ups) for my APC Back-UPS Pro 900V with usb cable connected. Working great! Setup FreeNAS as "NUT-server" that tells my other computer to shutdown
andrewjs18
looks like it's working fine for me. it sent me an email when it went on battery and when it was plugged back into the wall:
ONBATT - ups
ONLINE - ups
will this shut down both the freenas box and my web server that I have hooked up to the UPS or just the freenas box when it gets low on the battery?
