oRAirwolf
- Dec 6, 2016
I am trying to setup rsync between my FreeNAS machine and a backup server I purchased, which is a TerraMaster F4-220. It is basically a knock off of a QNAP/Synology machine, only much crappier (and cheap at $189 on Newegg Flash). It has an rsync daemon, but it can only be configured with a username and password. There are very few configuration options in the interface and you have no option but use credentials. I tried editing the rsyncd.conf file on the F4-220, but it overwrites the file on every reboot. It also deletes my SSH keys on every reboot. So I think my best option is to do an rsync push from FreeNAS with a secrets file. As far as I am aware, it is possible to create a secrets file that you can reference in your rsync command to authenticate. Since FreeNAS does not offer the option to input credentials when using rsync (not rsync over SSH) natively via the GUI, I assume I can do this via the extra command box at the bottom. The problem I am running into is that I cannot make the secrets file persistent. I tried storing the password file on my primary share, but when I try and run rsync with the password file, I get the following:
So I tried to chown and chmod it, but I get an error:
Is there a place I can store this file that will be persistent across reboots and will also let me change the permissions so it is not other-accessible?
root@epsilonshrike:~ # rsync -avp --password-file=/mnt/RAIDZ1Pool/RAIDZ1Pool/rsyncpassword /mnt/RAIDZ1Pool/RAIDZ1Pool/test airwolf@10.10.0.29::freenasbackup/RAIDZ1Pool
ERROR: password file must not be other-accessible
rsync error: syntax or usage error (code 1) at authenticate.c(196) [sender=3.1.2]So I tried to chown and chmod it, but I get an error:
root@epsilonshrike:~ # chown root /mnt/RAIDZ1Pool/RAIDZ1Pool/rsyncpassword
root@epsilonshrike:~ # ls -lA /mnt/RAIDZ1Pool/RAIDZ1Pool/rsyncpassword
-rwxrwxr-x+ 1 root wheel 22 Nov 21 01:42 /mnt/RAIDZ1Pool/RAIDZ1Pool/rsyncpassword
root@epsilonshrike:~ # chmod 600 /mnt/RAIDZ1Pool/RAIDZ1Pool/rsyncpassword
chmod: /mnt/RAIDZ1Pool/RAIDZ1Pool/rsyncpassword: Operation not permittedIs there a place I can store this file that will be persistent across reboots and will also let me change the permissions so it is not other-accessible?
