slimyguy
- Apr 4, 2023
I'm trying to set permissions for a pool that I originally created in truenas scale, (which I believe is not a supported thing)
and while trying to choose an ACL preset it gets stuck looping on a please wait message. Trying to manually, enter the settings as I see them in a tutorial I am following, I get this error
Error: [ENOTSUP] NFSv4 ACLS are not supported on path /mnt/temp big guy/bigo/secretdata-tut
CLOSE
There are a few threads I've found with a solution but I don't actually know how to use the solutions.
www.truenas.com
Here they say to use `zfs set acltype= nfsv4 pool/dataset` in the CLI, but I don't know where exactly?
I tried at the directory of the folder whose permissions I want to change, and tried straight away when I opened shell.
I'm sure this is very obvious to those who know what they're doing, but I don't which is why I moved from scale to core.
Thank you in advance.
CLOSE
Unable to set ACLs on newly imported pool
I just moved to Truenas 12 from OpenMediaVault with ZFS on Linux. I was able to import my old pool into Truenas, all data is there. Set back up my datasets but when I go to set up ACLs for sharing I get this error: [ENOTSUP] NFSv4 ACLS are not supported on path "*Insert path here*" It does...
