Where is the megarec Utility to Crossflash M1015 to IT Mode?
I am trying to cross flash the IBM Serveraid M1015 to IT mode, following this tutorial: (http://www.servethehome.com/ibm-serveraid-m1015-part-4/) but it looks like the link for the files in that article is currently down. (http://forums.laptopvideo2go.com/topic/29059-lsi-92xx-firmware-files/)
Does anyone have those files here?
I found the P16 firmware files on LSI's site, but I need the megarec utility and the sbrempty.bin as shown in the following commands
megarec -writesbr 0 sbrempty.bin
megarec -cleanflash 0
so that I can get sas2flsh to even recognize the card.
BigDave
FreeNAS Enthusiast
PM your email to me and I will zip them up and send it your way.
I have no other way, sorry
PM sent. I really do appreciate it.
Also, unless they are more than 25MB, you could post them here for others who might be looking for them too... If they are that big, though, my email will bounce it back.
They're available on LSI's website as well. Maybe not packaged with the P16 files, but with the latest files almost certainly.
Magnetic83
i'm having compatibility problems with the LSI 9240-4i and i've documented myself for an entire week.
The only one choice seem to be crossflashing it to a 9122 in IR mode (for my needs).
I just need to find the Megarec utility and the related files.
Zanginator, in another post talk about a zip with all the files needed to perform this action but i can't find his package anymore called Sas2008.
Anyone of you can help me ?
Can anyone PM me the needed files to crossflashing ?
Thank you in advance.
Spearfoot
He of the long foot
Here is the fileset I used to flash my M1015:
  • m1015.zip
Magnetic83
Thank you Spearfoot !!!!!!!!!!!:)
Now i can try to do the job...
If i can ask you, do you've used dos or uefi shell?
And the correct list of commands ? A lot of post with a lot of different commands sequence. How did you do that?
Magnetic83
Booted if efi shell, ok.
1. mount fs0 (ok)
2. fs0: (ok)
3. sas2flash.efi -listall (no lsi adapter found...)
4. megarec -writesbr 0 sbrempty.bin (megarec is not recognized as an internal or external program)
What can i do?
Spearfoot
He of the long foot
1. mount fs0 (ok)
2. fs0: (ok)
What can i do?
Hmmm... I would try booting DOS from a USB stick, instead of loading the UEFI shell. I don't think you can execute the megarec.exe program from a UEFI shell. I flashed my M1015 using DOS on an older PC, creating the bootable USB stick with Rufus.
I included two batch files in the zip archive. Before using them, you should run sas2flsh --listall and obtain the 16-digit SAS ID of your card; you will need to edit the second batch file and specify this ID where indicated.
The first (TOITMD1.BAT) runs these commands:
echo Reboot and run the next batch file
You should reboot the system after running this first batch file. Then run the second batch file (TOITMD2.BAT) which runs these commands:
sas2flsh -o -f 2118it.bin -b mptsas2.rom
REM Edit and specify your 16-digit Hex SAS address:
sas2flsh -o -sasadd XXXXXXXXXXXXXXXX
Note that you must edit this batch file, replacing the 'X's with the 16-digit SAS ID of your card!
Also, you can remove the '-b mptsas2.rom' specifier if you don't want to flash the option ROM onto the card.
Spearfoot
He of the long foot
Magnetic83
Oooops, the megarec is .exe not .efi... sorry! :D
Ok, i'll try and iìll give you a feedback after the operations, i hope it will work without problems.
Thank you again.
Murac
How's it going, i found these alternative instructions here: https://blog.grem.de/sysadmin/LSI-SAS2008-Flashing-2012-04-12-22-17.html
  1. Boot FreeDOS from USB thumb drive
  2. Check for available controllers (important):
    sas2flsh -listall
  3. Clean controller flash memory (without removing WWN, 0 is the controller number):
    sas2flsh -o -e 6 -c 0
  4. Flash firmware and OptionROM images (0 is the controller number):
    sas2flsh -o -f 2108it.bin -b mptsas2.rom -c 0
  5. Reboot into OS
a) Can I get away without the megarec utility with a 9210-8i?
b) if I use the files from your zip, should I copy my firmware files over to that fileset or can I just copy the megarec.exe file? (not sure if it has dependencies)
http://www.avagotech.com/products/server-storage/host-bus-adapters/sas-9210-8i#overview for reference
You only need megarec to erase cards that do not ship with IT/IR firmware.
Murac
And if my firmware mismatches the drivers? Still no megarec?
Spearfoot
He of the long foot
    sas2flsh -listall
  5. Reboot into OS
@Murac, there's a copy of megarec.exe in the M1015.ZIP file available above in post #6 in this thread.
No. You use sas2flash for all IR/IT firmware operations.
Fidget08
I feel like I'm so close. When I run Sas2flsh.exe I get an Error: Failed to initialize PAL. Exiting program. My Lenovo TS440 doesn't have UEFI so I can't go that route. Pretty sure I'm screwed for now till I can get an old computer from work to do this flash. Am I missing anything?
Spearfoot
He of the long foot
Fidget08
Well color me completely wrong. I guess I meant to say is that I can't find if it has a UEFI Shell built into the boot options.
Edit: I downloaded rEFInd Boot Manager and have successfully booted into an UEFI Shell.
