What kind of read/write performance should I be getting?
djdwosk97
1. Grab another 8GB of memory
2. Grab a $30 intel network card
3. to test write speed run this on a dataset that has compression disabled.
dd if=/dev/zero of=./21GB.dat bs=128k count=163840
4. to test read speed run this on a dataset that has compression disabled and also has the 21GB file created in the previous test.
dd of=/dev/null if=./21GB.dat bs=128k count=163840
Don't expect anything magical since your hardware is very 'iffy' and not recommended for freenas. For best results stick to recommended server hardware.
I don't believe your mobo is ECC compatible.
That's why I suggested you look at our recommendations.
Also, any idea why I always get this strange drive usage -- it only happens to this one drive:
gpsguy
Active Member
It's hard to say, especially since you have a non-standard configuration with 4 volumes.
Which drive is this? The Green, Barracuda, or one of the 4TB Reds? Did you run wdidle on your WD Green? If not, please do so.
Do you have the system dataset on it? See section 5.6 of the manual - http://doc.freenas.org/9.3/freenas_system.html#system-dataset
djdwosk97
That's one of the 4tb drives and the system dataset is on one of the 4tb drives -- I'm not sure if it's the same one, but that would make sense if it is.
How do I run wdidle (can/should I also run that on the Seagate drive -- I think it's a barracuda, but it may not be as it's a really old drive)
gpsguy
Active Member
wdidle is a Western Digital utility, you don't run it on the Seagate.
Here's a thread with more information on the issue - https://forums.freenas.org/index.php?threads/hacking-wd-greens-and-reds-with-wdidle3-exe.18171/
You might want to post the results of your smart test on the WD Green, to look at the stats. Go to the shell and type: smartctl -a /dev/adaX (or possibly /daX), where X is a number. It looks like your device names start with ada. If you do post the information, either use code tags or upload a picture. Formatting is important for readability.
djdwosk97
I think it's too late to bother with wdidle at this point. 1.2 million parks over the last 3.7 years.
I did notice two of (the first and third) my 4tb Reds have quite a few parks compared to the other one (4000~ vs. 200~).
Model Family: Seagate Barracuda 7200.12
Device Model: ST31000528AS
Serial Number: 5VP253Z9
LU WWN Device Id: 5 000c50 01c4ee5d6
Firmware Version: CC38
User Capacity: 1,000,204,886,016 bytes [1.00 TB]
Sector Size: 512 bytes logical/physical
Rotation Rate: 7200 rpm
ATA Version is: ATA8-ACS T13/1699-D revision 4
SATA Version is: SATA 2.6, 3.0 Gb/s
Local Time is: Thu Jan 14 20:09:20 2016 EST
==> WARNING: A firmware update for this drive may be available,
see the following Seagate web pages:
http://knowledge.seagate.com/articles/en_US/FAQ/207931en
http://knowledge.seagate.com/articles/en_US/FAQ/213891en
SMART support is: Enabled
See vendor-specific Attribute list for marginal Attributes.
General SMART Values:
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
been run.
data collection: ( 609) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 184) minutes.
Conveyance self-test routine
SCT capabilities: (0x103f) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x000f 118 099 006 Pre-fail Always - 174938364
3 Spin_Up_Time 0x0003 095 094 000 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 587
5 Reallocated_Sector_Ct 0x0033 100 100 036 Pre-fail Always - 0
7 Seek_Error_Rate 0x000f 062 055 030 Pre-fail Always - 81631161461
9 Power_On_Hours 0x0032 091 091 000 Old_age Always - 8519
10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 127
183 Runtime_Bad_Block 0x0032 100 100 000 Old_age Always - 0
184 End-to-End_Error 0x0032 100 100 099 Old_age Always - 0
187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0
188 Command_Timeout 0x0032 100 099 000 Old_age Always - 42950328330
189 High_Fly_Writes 0x003a 098 098 000 Old_age Always - 2
190 Airflow_Temperature_Cel 0x0022 072 043 045 Old_age Always In_the_past 28 (0 5 31 20 0)
194 Temperature_Celsius 0x0022 028 057 000 Old_age Always - 28 (0 15 0 0 0)
195 Hardware_ECC_Recovered 0x001a 039 024 000 Old_age Always - 174938364
197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 5385 (129 77 0)
241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 123308529
242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 1047558603
SMART Error Log Version: 1
No Errors Logged
# 1 Short offline Completed without error 00% 8454 -
# 2 Extended offline Completed without error 00% 8362 -
# 3 Short offline Completed without error 00% 8286 -
# 4 Extended offline Completed without error 00% 8121 -
# 5 Extended offline Completed without error 00% 7954 -
# 6 Extended offline Completed without error 00% 7786 -
# 7 Extended offline Completed without error 00% 7618 -
# 8 Extended offline Completed without error 00% 7449 -
# 9 Extended offline Completed without error 00% 7401 -
#10 Extended offline Completed without error 00% 7233 -
#11 Extended offline Completed without error 00% 7065 -
#12 Extended offline Interrupted (host reset) 00% 6897 -
#13 Extended offline Completed without error 00% 6729 -
#14 Extended offline Completed without error 00% 6656 -
#15 Extended offline Completed without error 00% 6488 -
#16 Extended offline Completed without error 00% 6320 -
#17 Extended offline Completed without error 00% 6152 -
#18 Extended offline Completed without error 00% 6054 -
#19 Extended offline Completed without error 00% 5885 -
#20 Extended offline Completed without error 00% 5813 -
#21 Extended offline Completed without error 00% 5645 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
(END)
Model Family: Western Digital Caviar Green (AF)
Device Model: WDC WD10EARS-00MVWB0
Serial Number: WD-WCAZA0709278
LU WWN Device Id: 5 0014ee 25a4a1057
Firmware Version: 51.0AB51
ATA Version is: ATA8-ACS (minor revision not indicated)
Local Time is: Thu Jan 14 20:11:31 2016 EST
Offline data collection status: (0x84) Offline data collection activity
was suspended by an interrupting command from host.
been run.
data collection: (17880) seconds.
command.
power-saving mode.
recommended polling time: ( 175) minutes.
recommended polling time: ( 5) minutes.
SCT capabilities: (0x3035) SCT Status supported.
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0
3 Spin_Up_Time 0x0027 174 163 021 Pre-fail Always - 6291
4 Start_Stop_Count 0x0032 088 088 000 Old_age Always - 12641
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0
9 Power_On_Hours 0x0032 056 056 000 Old_age Always - 32161
10 Spin_Retry_Count 0x0032 100 100 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 100 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 118
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 71
193 Load_Cycle_Count 0x0032 001 001 000 Old_age Always - 1225257
194 Temperature_Celsius 0x0022 119 089 000 Old_age Always - 31
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 200 200 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 11
No Errors Logged
# 1 Short offline Completed without error 00% 32096 -
# 2 Extended offline Completed without error 00% 32004 -
# 3 Short offline Completed without error 00% 31929 -
# 4 Extended offline Completed without error 00% 31764 -
# 5 Extended offline Completed without error 00% 31597 -
# 6 Extended offline Completed without error 00% 31429 -
# 7 Extended offline Completed without error 00% 31262 -
# 8 Extended offline Completed without error 00% 31094 -
# 9 Extended offline Completed without error 00% 31046 -
#10 Extended offline Completed without error 00% 30878 -
#11 Extended offline Completed without error 00% 30710 -
#12 Extended offline Completed without error 00% 30375 -
#13 Extended offline Completed without error 00% 30302 -
#14 Extended offline Completed without error 00% 30134 -
#15 Extended offline Completed without error 00% 29966 -
#16 Extended offline Completed without error 00% 29799 -
#17 Extended offline Completed without error 00% 29700 -
#18 Extended offline Completed without error 00% 29532 -
#19 Extended offline Completed without error 00% 29460 -
#20 Extended offline Completed without error 00% 29292 -
#21 Extended offline Completed without error 00% 29124 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
(END)
Model Family: Western Digital Red
Device Model: WDC WD40EFRX-68WT0N0
Serial Number: WD-WCC4E1FK8H1A
LU WWN Device Id: 5 0014ee 2b66caf33
Firmware Version: 82.00A82
User Capacity: 4,000,787,030,016 bytes [4.00 TB]
Rotation Rate: 5400 rpm
ATA Version is: ACS-2 (minor revision not indicated)
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Thu Jan 14 20:24:31 2016 EST
was never started.
been run.
data collection: (52380) seconds.
command.
power-saving mode.
recommended polling time: ( 524) minutes.
SCT capabilities: (0x703d) SCT Status supported.
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 3
3 Spin_Up_Time 0x0027 194 178 021 Pre-fail Always - 7275
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 21
9 Power_On_Hours 0x0032 095 095 000 Old_age Always - 4082
10 Spin_Retry_Count 0x0032 100 253 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 20
193 Load_Cycle_Count 0x0032 199 199 000 Old_age Always - 3936
194 Temperature_Celsius 0x0022 122 111 000 Old_age Always - 30
198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0
No Errors Logged
# 1 Extended offline Completed without error 00% 3932 -
# 2 Extended offline Completed without error 00% 3692 -
# 3 Extended offline Completed without error 00% 3524 -
# 4 Extended offline Completed without error 00% 3357 -
# 5 Extended offline Completed without error 00% 3189 -
# 6 Extended offline Completed without error 00% 3021 -
# 7 Extended offline Completed without error 00% 2973 -
# 8 Extended offline Completed without error 00% 2805 -
# 9 Extended offline Completed without error 00% 2642 -
#10 Extended offline Completed without error 00% 2301 -
#11 Extended offline Completed without error 00% 2229 -
#12 Extended offline Completed without error 00% 2061 -
#13 Extended offline Completed without error 00% 1894 -
#14 Extended offline Completed without error 00% 1726 -
#15 Extended offline Completed without error 00% 1627 -
#16 Extended offline Completed without error 00% 1459 -
#17 Extended offline Completed without error 00% 1387 -
#18 Extended offline Completed without error 00% 1219 -
#19 Extended offline Completed without error 00% 1051 -
#20 Extended offline Completed without error 00% 884 -
#21 Extended offline Completed without error 00% 717 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
(END)
Serial Number: WD-WCC4EKPA0KVN
LU WWN Device Id: 5 0014ee 20b04ebad
Local Time is: Thu Jan 14 20:27:05 2016 EST
was never started.
been run.
data collection: (53280) seconds.
command.
power-saving mode.
recommended polling time: ( 532) minutes.
3 Spin_Up_Time 0x0027 189 172 021 Pre-fail Always - 7508
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 25
9 Power_On_Hours 0x0032 095 095 000 Old_age Always - 4059
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 24
193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 221
194 Temperature_Celsius 0x0022 123 114 000 Old_age Always - 29
200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 0
No Errors Logged
# 1 Short offline Completed without error 00% 3994 -
# 2 Extended offline Completed without error 00% 3908 -
# 3 Short offline Completed without error 00% 3826 -
# 4 Extended offline Completed without error 00% 3668 -
# 5 Extended offline Completed without error 00% 3501 -
# 6 Extended offline Completed without error 00% 3333 -
# 7 Extended offline Completed without error 00% 3165 -
# 8 Extended offline Completed without error 00% 2997 -
# 9 Extended offline Completed without error 00% 2949 -
#10 Extended offline Completed without error 00% 2782 -
#11 Extended offline Completed without error 00% 2614 -
#12 Extended offline Completed without error 00% 2278 -
#13 Extended offline Completed without error 00% 2205 -
#14 Extended offline Completed without error 00% 2037 -
#15 Extended offline Completed without error 00% 1903 -
#16 Extended offline Completed without error 00% 1735 -
#17 Extended offline Completed without error 00% 1636 -
#18 Extended offline Completed without error 00% 1468 -
#19 Extended offline Completed without error 00% 1396 -
#20 Extended offline Completed without error 00% 1244 -
#21 Extended offline Completed without error 00% 1076 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
(END)
Serial Number: WD-WCC4E6YUY983
LU WWN Device Id: 5 0014ee 2b66d61f7
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is: Thu Jan 14 20:29:04 2016 EST
was never started.
been run.
data collection: (52860) seconds.
command.
power-saving mode.
recommended polling time: ( 529) minutes.
3 Spin_Up_Time 0x0027 196 180 021 Pre-fail Always - 7158
9 Power_On_Hours 0x0032 095 095 000 Old_age Always - 4080
193 Load_Cycle_Count 0x0032 199 199 000 Old_age Always - 4109
194 Temperature_Celsius 0x0022 123 115 000 Old_age Always - 29
200 Multi_Zone_Error_Rate 0x0008 100 253 000 Old_age Offline - 0
No Errors Logged
No self-tests have been logged. [To run self-tests, use: smartctl -t]
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
(END)
gpsguy
Active Member
Yeah, given that it's rated for ~300,000 ... I'd be careful what I put on the mirror.
I don't why there's a difference on your 4TB drives. I did compare the firmware, all three are the same. In any event, I wouldn't worry about it.
djdwosk97
Actually, I think I know why the second drive has a low number of park cycles....that drive was sitting idle in my server for a while as I didn't yet have any data to throw on it.
Everything that's on my raid1 array is backed up on at least one other drive (off the server). But that's also partially why I put the drives in Raid 1 because both were pulled out of external drives I've bought/been given over the years (I mean, that barracuda is from 2009).
And alright.
Ummm, another random question -- what would you guess is the likelihood of there being a serious error caused by not having ECC memory (since most of the content on the server is movies, bitrot isn't really a concern)?
P.p.s. any recommendations for a 400-500w UPS (something just long enough for the server to power itself down)? I do have a concern with a UPS though, my server is on top of a wood cabinet so I'm somewhat concerned with a UPS being a fire hazard -- what would be the likelihood and worst case scenario outcomes of a sudden power failure (without a UPS)?
