SwisherSweet
- May 13, 2017
I have have a zfs pool with one vdev with 5 drives in RAID Z1. I want to expand the pool by adding a second vdev with 5 drives in RAID Z1, but I will be adding them via external expansion unit.
My concern is if there is any hardware issue (data or power cable, psu failure) where the entire expansion unit becomes inaccessible for some reason, I assume the pool will crash. However, if I correct the problem (such as PSU failure), would I be able to recover the pool and if so, how would I do that?
Note, I am using latest TrueNAS Core. I'm running a Mac Pro with 5 drives connecting to the SATA ports. I'll be using an external esata enclosure. This is a home backup server. I have 3 other copies of the data.
Thank you.
Thank you.
