They've released a list: https://blog.westerndigital.com/wd-red-nas-drives
root@freenas2-pmh[~]# smartctl -x /dev/ada0
smartctl 7.0 2018-12-30 r4883 [FreeBSD 11.3-RELEASE-p7 amd64] (local build)
Copyright (C) 2002-18, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family: Western Digital Red
Device Model: WDC WD40EFRX-68N32N0
Serial Number: ***************
LU WWN Device Id: 5 0014ee 2bd12a574
Firmware Version: 82.00A82
User Capacity: 4,000,787,030,016 bytes [4.00 TB]
Rotation Rate: 5400 rpm
Form Factor: 3.5 inches
ATA Version is: ACS-3 T13/2161-D revision 5
SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Thu Apr 23 14:40:07 2020 PDT
SMART support is: Enabled
AAM feature is: Unavailable
APM feature is: Unavailable
Rd look-ahead is: Enabled
Write cache is: Enabled
DSN feature is: Unavailable
ATA Security is: Disabled, NOT FROZEN [SEC1]
Wt Cache Reorder: Enabled
General SMART Values:
was never started.
been run.
data collection: (43560) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 463) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x303d) SCT Status supported.
SCT Data Table supported.
ID# ATTRIBUTE_NAME FLAGS VALUE WORST THRESH FAIL RAW_VALUE
1 Raw_Read_Error_Rate POSR-K 100 253 051 - 0
3 Spin_Up_Time POS--K 246 243 021 - 2683
4 Start_Stop_Count -O--CK 100 100 000 - 12
5 Reallocated_Sector_Ct PO--CK 200 200 140 - 0
7 Seek_Error_Rate -OSR-K 100 253 000 - 0
9 Power_On_Hours -O--CK 100 100 000 - 6
10 Spin_Retry_Count -O--CK 100 253 000 - 0
11 Calibration_Retry_Count -O--CK 100 253 000 - 0
12 Power_Cycle_Count -O--CK 100 100 000 - 12
192 Power-Off_Retract_Count -O--CK 200 200 000 - 9
193 Load_Cycle_Count -O--CK 200 200 000 - 4
194 Temperature_Celsius -O---K 116 115 000 - 34
196 Reallocated_Event_Count -O--CK 200 200 000 - 0
197 Current_Pending_Sector -O--CK 200 200 000 - 0
198 Offline_Uncorrectable ----CK 100 253 000 - 0
199 UDMA_CRC_Error_Count -O--CK 200 200 000 - 0
200 Multi_Zone_Error_Rate ---R-- 100 253 000 - 0
||||||_ K auto-keep
|||||__ C event count
||||___ R error rate
|||____ S speed/performance
||_____ O updated online
|______ P prefailure warning
General Purpose Log Directory Version 1
SMART Log Directory Version 1 [multi-sector log support]
Address Access R/W Size Description
0x00 GPL,SL R/O 1 Log Directory
0x01 SL R/O 1 Summary SMART error log
0x02 SL R/O 5 Comprehensive SMART error log
0x03 GPL R/O 6 Ext. Comprehensive SMART error log
0x04 GPL,SL R/O 8 Device Statistics log
0x06 SL R/O 1 SMART self-test log
0x07 GPL R/O 1 Extended self-test log
0x09 SL R/W 1 Selective self-test log
0x10 GPL R/O 1 NCQ Command Error log
0x11 GPL R/O 1 SATA Phy Event Counters log
0x30 GPL,SL R/O 9 IDENTIFY DEVICE data log
0x80-0x9f GPL,SL R/W 16 Host vendor specific log
0xa0-0xa7 GPL,SL VS 16 Device vendor specific log
0xa8-0xb6 GPL,SL VS 1 Device vendor specific log
0xb7 GPL,SL VS 56 Device vendor specific log
0xbd GPL,SL VS 1 Device vendor specific log
0xc0 GPL,SL VS 1 Device vendor specific log
0xc1 GPL VS 93 Device vendor specific log
0xe0 GPL,SL R/W 1 SCT Command/Status
0xe1 GPL,SL R/W 1 SCT Data Transfer
SMART Extended Comprehensive Error Log Version: 1 (6 sectors)
No Errors Logged
SMART Extended Self-test Log Version: 1 (1 sectors)
No self-tests have been logged. [To run self-tests, use: smartctl -t]
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
SCT Status Version: 3
SCT Version (vendor specific): 258 (0x0102)
Device State: Active (0)
Current Temperature: 34 Celsius
Power Cycle Min/Max Temperature: 32/35 Celsius
Lifetime Min/Max Temperature: 24/35 Celsius
Under/Over Temperature Limit Count: 0/0
Vendor specific:
01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
SCT Temperature History Version: 2
Temperature Sampling Period: 1 minute
Temperature Logging Interval: 1 minute
Min/Max recommended Temperature: 0/65 Celsius
Min/Max Temperature Limit: -41/85 Celsius
Temperature History Size (Index): 478 (367)
Index Estimated Time Temperature Celsius
368 2020-04-23 06:43 ? -
... ..(109 skipped). .. -
0 2020-04-23 08:33 ? -
1 2020-04-23 08:34 24 *****
2 2020-04-23 08:35 24 *****
3 2020-04-23 08:36 25 ******
4 2020-04-23 08:37 25 ******
5 2020-04-23 08:38 25 ******
6 2020-04-23 08:39 26 *******
7 2020-04-23 08:40 26 *******
8 2020-04-23 08:41 26 *******
9 2020-04-23 08:42 27 ********
10 2020-04-23 08:43 ? -
11 2020-04-23 08:44 28 *********
12 2020-04-23 08:45 28 *********
13 2020-04-23 08:46 28 *********
14 2020-04-23 08:47 ? -
15 2020-04-23 08:48 29 **********
... ..( 5 skipped). .. **********
21 2020-04-23 08:54 29 **********
22 2020-04-23 08:55 30 ***********
... ..( 21 skipped). .. ***********
44 2020-04-23 09:17 30 ***********
45 2020-04-23 09:18 31 ************
... ..( 8 skipped). .. ************
54 2020-04-23 09:27 31 ************
55 2020-04-23 09:28 ? -
56 2020-04-23 09:29 31 ************
... ..( 4 skipped). .. ************
61 2020-04-23 09:34 31 ************
62 2020-04-23 09:35 32 *************
63 2020-04-23 09:36 32 *************
64 2020-04-23 09:37 ? -
65 2020-04-23 09:38 32 *************
66 2020-04-23 09:39 32 *************
67 2020-04-23 09:40 ? -
68 2020-04-23 09:41 32 *************
69 2020-04-23 09:42 32 *************
70 2020-04-23 09:43 32 *************
71 2020-04-23 09:44 ? -
72 2020-04-23 09:45 32 *************
... ..( 24 skipped). .. *************
97 2020-04-23 10:10 32 *************
98 2020-04-23 10:11 33 **************
... ..( 35 skipped). .. **************
134 2020-04-23 10:47 33 **************
135 2020-04-23 10:48 ? -
136 2020-04-23 10:49 33 **************
... ..( 3 skipped). .. **************
140 2020-04-23 10:53 33 **************
141 2020-04-23 10:54 ? -
142 2020-04-23 10:55 33 **************
143 2020-04-23 10:56 32 *************
... ..( 2 skipped). .. *************
146 2020-04-23 10:59 32 *************
147 2020-04-23 11:00 ? -
148 2020-04-23 11:01 33 **************
149 2020-04-23 11:02 33 **************
150 2020-04-23 11:03 32 *************
... ..( 5 skipped). .. *************
156 2020-04-23 11:09 32 *************
157 2020-04-23 11:10 ? -
158 2020-04-23 11:11 33 **************
159 2020-04-23 11:12 33 **************
160 2020-04-23 11:13 ? -
161 2020-04-23 11:14 33 **************
162 2020-04-23 11:15 32 *************
... ..( 84 skipped). .. *************
247 2020-04-23 12:40 32 *************
248 2020-04-23 12:41 33 **************
... ..( 46 skipped). .. **************
295 2020-04-23 13:28 33 **************
296 2020-04-23 13:29 34 ***************
... ..( 19 skipped). .. ***************
316 2020-04-23 13:49 34 ***************
317 2020-04-23 13:50 35 ****************
... ..( 17 skipped). .. ****************
335 2020-04-23 14:08 35 ****************
336 2020-04-23 14:09 34 ***************
... ..( 30 skipped). .. ***************
367 2020-04-23 14:40 34 ***************
SCT Error Recovery Control:
Read: 70 (7.0 seconds)
Write: 70 (7.0 seconds)
Device Statistics (GP Log 0x04)
Page Offset Size Value Flags Description
0x01 ===== = = === == General Statistics (rev 1) ==
0x01 0x008 4 12 --- Lifetime Power-On Resets
0x01 0x010 4 6 --- Power-on Hours
0x01 0x018 6 442135935 --- Logical Sectors Written
0x01 0x020 6 10934246 --- Number of Write Commands
0x01 0x028 6 941592 --- Logical Sectors Read
0x01 0x030 6 146734 --- Number of Read Commands
0x01 0x038 6 21600000 --- Date and Time TimeStamp
0x03 ===== = = === == Rotating Media Statistics (rev 1) ==
0x03 0x008 4 5 --- Spindle Motor Power-on Hours
0x03 0x010 4 5 --- Head Flying Hours
0x03 0x018 4 14 --- Head Load Events
0x03 0x020 4 0 --- Number of Reallocated Logical Sectors
0x03 0x028 4 0 --- Read Recovery Attempts
0x03 0x030 4 0 --- Number of Mechanical Start Failures
0x03 0x038 4 0 --- Number of Realloc. Candidate Logical Sectors
0x03 0x040 4 9 --- Number of High Priority Unload Events
0x04 ===== = = === == General Errors Statistics (rev 1) ==
0x04 0x008 4 0 --- Number of Reported Uncorrectable Errors
0x04 0x010 4 0 --- Resets Between Cmd Acceptance and Completion
0x05 ===== = = === == Temperature Statistics (rev 1) ==
0x05 0x008 1 34 --- Current Temperature
0x05 0x010 1 - --- Average Short Term Temperature
0x05 0x018 1 - --- Average Long Term Temperature
0x05 0x020 1 35 --- Highest Temperature
0x05 0x028 1 30 --- Lowest Temperature
0x05 0x030 1 - --- Highest Average Short Term Temperature
0x05 0x038 1 - --- Lowest Average Short Term Temperature
0x05 0x040 1 - --- Highest Average Long Term Temperature
0x05 0x048 1 - --- Lowest Average Long Term Temperature
0x05 0x050 4 0 --- Time in Over-Temperature
0x05 0x058 1 65 --- Specified Maximum Operating Temperature
0x05 0x060 4 0 --- Time in Under-Temperature
0x05 0x068 1 0 --- Specified Minimum Operating Temperature
0x06 ===== = = === == Transport Statistics (rev 1) ==
0x06 0x008 4 39 --- Number of Hardware Resets
0x06 0x010 4 14 --- Number of ASR Events
0x06 0x018 4 0 --- Number of Interface CRC Errors
|||_ C monitored condition met
||__ D supports DSN
|___ N normalized value
Pending Defects log (GP Log 0x0c) not supported
SATA Phy Event Counters (GP Log 0x11)
ID Size Value Description
0x0001 2 0 Command failed due to ICRC error
0x0002 2 0 R_ERR response for data FIS
0x0003 2 0 R_ERR response for device-to-host data FIS
0x0004 2 0 R_ERR response for host-to-device data FIS
0x0005 2 0 R_ERR response for non-data FIS
0x0006 2 0 R_ERR response for device-to-host non-data FIS
0x0007 2 0 R_ERR response for host-to-device non-data FIS
0x0008 2 0 Device-to-host non-data FIS retries
0x0009 2 2 Transition from drive PhyRdy to drive PhyNRdy
0x000a 2 3 Device-to-host register FISes sent due to a COMRESET
0x000b 2 0 CRC errors within host-to-device FIS
0x000d 2 0 Non-CRC errors within host-to-device FIS
0x000f 2 0 R_ERR response for host-to-device data FIS, CRC
0x0012 2 0 R_ERR response for host-to-device non-data FIS, CRC
0x8000 4 12449 Vendor specificthe WD EFRX are silent! Like in "no contest", specifically when compared to my Toshiba N300
deserves the fate of the Sirius Cybernetics Corporation's marketing department.
Honestly, I had no idea about the rotational speed. At the time I bought the Toshiba drives our company's default supplier (ALSO) did not offer anything I found attractively priced (for a hobby setup) and at Amazon the most frequent problem with disk drives seemed to be inadequate packaging of OEM products according to the reviews. I picked the N300 because they were reasonably priced and sold as a "retail product" with a complete shiny package around each single disk. No kidding, that was my main motivation. They have not failed me since, but they do make themselves noticed ;)I think rotational speed has a lot to do with that, 5400 vs 7200.
Pity we'll have to wait for the revolution before that happens...deserves the fate of the Sirius Cybernetics Corporation's marketing department.
Newegg has the 4TB EFRX for $90 shipped today. On Amazon you can get a certified refurbished one for $145!
Model Family: Western Digital Red Device Model: WDC WD80EFAX-68KNBN0 Serial Number: XXXXXXXXXXX LU WWN Device Id: 5 000cca 099c5257c Firmware Version: 81.00A81 User Capacity: 8,001,563,222,016 bytes [8.00 TB] Sector Sizes: 512 bytes logical, 4096 bytes physical Rotation Rate: 5400 rpm Form Factor: 3.5 inches Device is: In smartctl database [for details use: -P show] ATA Version is: ACS-2, ATA8-ACS T13/1699-D revision 4 SATA Version is: SATA 3.2, 6.0 Gb/s (current: 3.0 Gb/s) Local Time is: Fri Apr 24 12:17:48 2020 NZST SMART support is: Available - device has SMART capability. SMART support is: Enabled
I have a WD Red 8TB with EFAX in the model number
I paid a lot more for the WD Red drive to possibly get an inferior not fit for purpose SMR drive
WD80EFAX-xxKNBNx 8TB (5/10)*
Check the R/N! If it's still US7SAN8T0, then that's still a HGST DC HC320. Platter size is well below 2TB. If this was SMR, we'd expect 4 platters, 8 heads. The platter size DB is really helpful, when trusting manufacturers is hard. It's here: https://rml527.blogspot.com/2010/10/hdd-platter-database-western-digital-35_9883.html*Note: Rebadged HGST Ultrastar 7K8 / DC HC320 model, given the identical "US7SAN8T0" R/N on the label and obvious exterior similarities. The official datasheet claims "5400 RPM Class", but the amperage ratings on the label (5V 0.7A, 12V 0.9A) are the same as found on the higher-RPM WD8003FFBX below, arousing one's curiosity.
To a normal person there is every reason to believe drives with EFAX drive are SMR, 2-6TB drive like this are larger drives with the same naming are CMR, this is confusing, you have convinced me I'm fineThere's no reason to believe the WD80EFAX is SMR.
Is there a reason why they would not list Gold drives
@maclark7029 You are resilvering? You are seeing the dreaded IDNF errors, the firmware bug that WD insists is not a firmware bug. With other DM-SMR drives, resilver would eventually finish, after 5 days or so. This one, it’ll fail out of the vdev.
There might be ways around this - turn off write cache, a couple other tweaks, and waiting for even longer - and, you want no part of this. If you can, return the drive, and get something else.
