FreeNasNas
 - Jun 23, 2016
I hope you can help a FreeNAS newbie. A few weeks ago I installed FreeNAS-9.10.1-U2 (f045a8b) on a Thumb drive to test it on my system:
Motherboard: Supermicro A1SAi-2750F
RAM: 4x 8GB Kingston ECC
HDD: 4x WD-Red 2TB (RaidZ2, encrypted)
UPS: APC BR900G-GR
Until yesterday, everything works fine, but today I can't login to the Web-Gui. My thought was the password change for user root. I used IPMI to get a shell and changed the root password to something simple. Now I can login via SSH (as root) with the new password, but not on the Web-Gui. I always get "username or password wrong".
There are two things I changed yesterday:
* I installed and configured the UPS (It worked/works)
* I tried to set up Link Aggregation for the NICs but didn't work, so I deleted the lagg interface and use normal network setup.
I also changed nothing on the Web-Gui, no SSL, etc. I can't find the reason why this happens. The next thing is, I'm not able to decrypt the "zpool". If i enter "zpool status", the only pool I get is the thumb drive with FreeNAS but not the WD-Red pool. I have backups of all the data on that pool, so I will not loose any data, but it would be nice to unlock the pool.
I hope you can help me.
UPS: APC BR900G-GR
