Thanks to all for the help. I changed my idle timer to 300 after reading joeschmuck post.  Here is my new smart value with new drives.
smartctl 6.2 2013-07-26 r3841 [FreeBSD 9.2-RELEASE amd64] (local build)
Copyright (C) 2002-13, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family:    Western Digital VelociRaptor
Device Model:    WDC WD1500HLHX-01JJPV0
Serial Number:    WD-WX81E81XXXX
LU WWN Device Id: 5 0014ee 6579bd5ad
Firmware Version: 04.05G04
User Capacity:    150,039,945,216 bytes [150 GB]
Sector Size:      512 bytes logical/physical
Rotation Rate:    10000 rpm
ATA Version is:  ATA8-ACS (minor revision not indicated)
SATA Version is:  SATA 2.6, 6.0 Gb/s
Local Time is:    Tue Jan 14 16:32:31 2014 CST
SMART support is: Enabled
Power mode is:    ACTIVE or IDLE
ID# ATTRIBUTE_NAME          FLAG    VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate    0x002f  200  200  051    Pre-fail  Always      -      0
3 Spin_Up_Time            0x0027  192  191  021    Pre-fail  Always      -      1400
4 Start_Stop_Count        0x0032  100  100  000    Old_age  Always      -      135
5 Reallocated_Sector_Ct  0x0033  200  200  140    Pre-fail  Always      -      0
7 Seek_Error_Rate        0x002e  200  200  000    Old_age  Always      -      0
9 Power_On_Hours          0x0032  093  093  000    Old_age  Always      -      5169
10 Spin_Retry_Count        0x0032  100  100  000    Old_age  Always      -      0
11 Calibration_Retry_Count 0x0032  100  100  000    Old_age  Always      -      0
12 Power_Cycle_Count      0x0032  100  100  000    Old_age  Always      -      123
192 Power-Off_Retract_Count 0x0032  200  200  000    Old_age  Always      -      68
193 Load_Cycle_Count        0x0032  200  200  000    Old_age  Always      -      66
194 Temperature_Celsius    0x0022  113  107  000    Old_age  Always      -      30
196 Reallocated_Event_Count 0x0032  200  200  000    Old_age  Always      -      0
197 Current_Pending_Sector  0x0032  200  200  000    Old_age  Always      -      0
198 Offline_Uncorrectable  0x0030  200  200  000    Old_age  Offline      -      0
199 UDMA_CRC_Error_Count    0x0032  200  168  000    Old_age  Always      -      548
200 Multi_Zone_Error_Rate  0x0008  200  200  000    Old_age  Offline      -      0
SMART Error Log Version: 1
No Errors Logged
Model Family:    Western Digital Red (AF)
Device Model:    WDC WD20EFRX-68EUZN0
Serial Number:    WD-WCC4M09XXXX
LU WWN Device Id: 5 0014ee 25edbaaff
Firmware Version: 80.00A80
User Capacity:    2,000,398,934,016 bytes [2.00 TB]
Sector Sizes:    512 bytes logical, 4096 bytes physical
Rotation Rate:    5400 rpm
ATA Version is:  ACS-2 (minor revision not indicated)
SATA Version is:  SATA 3.0, 6.0 Gb/s (current: 3.0 Gb/s)
1 Raw_Read_Error_Rate    0x002f  100  253  051    Pre-fail  Always      -      0
3 Spin_Up_Time            0x0027  184  184  021    Pre-fail  Always      -      3775
4 Start_Stop_Count        0x0032  100  100  000    Old_age  Always      -      6
7 Seek_Error_Rate        0x002e  100  253  000    Old_age  Always      -      0
9 Power_On_Hours          0x0032  100  100  000    Old_age  Always      -      0
10 Spin_Retry_Count        0x0032  100  253  000    Old_age  Always      -      0
11 Calibration_Retry_Count 0x0032  100  253  000    Old_age  Always      -      0
12 Power_Cycle_Count      0x0032  100  100  000    Old_age  Always      -      6
192 Power-Off_Retract_Count 0x0032  200  200  000    Old_age  Always      -      5
193 Load_Cycle_Count        0x0032  200  200  000    Old_age  Always      -      2
194 Temperature_Celsius    0x0022  118  115  000    Old_age  Always      -      29
198 Offline_Uncorrectable  0x0030  100  253  000    Old_age  Offline      -      0
199 UDMA_CRC_Error_Count    0x0032  200  200  000    Old_age  Always      -      0
200 Multi_Zone_Error_Rate  0x0008  100  253  000    Old_age  Offline      -      0
No Errors Logged
Serial Number:    WD-WCC4M097XXXX
LU WWN Device Id: 5 0014ee 2b4319f78
3 Spin_Up_Time            0x0027  100  253  021    Pre-fail  Always      -      0
4 Start_Stop_Count        0x0032  100  100  000    Old_age  Always      -      4
12 Power_Cycle_Count      0x0032  100  100  000    Old_age  Always      -      4
192 Power-Off_Retract_Count 0x0032  200  200  000    Old_age  Always      -      3
193 Load_Cycle_Count        0x0032  200  200  000    Old_age  Always      -      1
194 Temperature_Celsius    0x0022  118  118  000    Old_age  Always      -      29
No Errors Logged
Serial Number:    WD-WMC4N081XXXX
LU WWN Device Id: 5 0014ee 6ae986a24
3 Spin_Up_Time            0x0027  199  199  021    Pre-fail  Always      -      5033
194 Temperature_Celsius    0x0022  121  121  000    Old_age  Always      -      29
No Errors Logged
Serial Number:    WD-WMC4M150XXXX
LU WWN Device Id: 5 0014ee 6ae9c7634
3 Spin_Up_Time            0x0027  216  191  021    Pre-fail  Always      -      2191
4 Start_Stop_Count        0x0032  100  100  000    Old_age  Always      -      9
12 Power_Cycle_Count      0x0032  100  100  000    Old_age  Always      -      9
192 Power-Off_Retract_Count 0x0032  200  200  000    Old_age  Always      -      8
194 Temperature_Celsius    0x0022  120  118  000    Old_age  Always      -      27
No Errors Logged
Serial Number:    WD-WMC4M145XXXX
LU WWN Device Id: 5 0014ee 0ae5a1884
3 Spin_Up_Time            0x0027  203  192  021    Pre-fail  Always      -      2841
4 Start_Stop_Count        0x0032  100  100  000    Old_age  Always      -      8
12 Power_Cycle_Count      0x0032  100  100  000    Old_age  Always      -      8
192 Power-Off_Retract_Count 0x0032  200  200  000    Old_age  Always      -      7
193 Load_Cycle_Count        0x0032  200  200  000    Old_age  Always      -      3
194 Temperature_Celsius    0x0022  119  118  000    Old_age  Always      -      28
No Errors Logged
Use smartctl -h to get a usage summary
