Warning on ./System/cores dataset size
hatem5000
Hello Folks,
I just got a warning on my Truenas machine that my Poolxx/.system/cores dataset occupies 92% of total qouta size of 1GB .. while i still got about 2TB on the pool free !!
When i tried to find the dataset to incrrase its qouta, i didn't find it..any idea how can i increase this dataset size ?!!
Thanks ...
Samuel Tai
Look in /var/db/system/cores. Those are where the core dumps live. You can't increase the quota for these, but you can delete the core files to reclaim space.
hatem5000
I deleted all files in that directory but they were about 70MB total so not much a difference .. hence is there another place i can empty it ?!!
