Hi viniciusferrao,
Like cyberjock said, in normal use your system shouldn't touch the swap file. The benefit of these 2GB swap partitions comes in when you have a situation where it would need to swap it has somewhere to swap to. The swap partitions also act as a hedge of sorts when you replace a failed drive.....if the new drive is just a touch to small you wouldn't be able to use it, but FreeNAS can use some of that swap space that would usually be assigned to the swap partition to give the data partition enough room to be added to the pool.
-Will
