I want to achieve a communication between two VMs without leaving traffic.
So what I did is I create a VLAN and assigned a ethernet port to it. As I could not assign the VLAN to the VMs (Device busy) I created a Bridge with the same parent ethernet port and added the VLAN as a member. Then I assigned the Bridge to the VMs.
Is that the correct way to do it?
Seems like one step too much.
Thank you
Thank you
