Sweet!
You don't need to change anything if it's working.
I just want to reiterate that "LAN" is merely the name of the network configured in Unifi that's assigned to VLAN 1.
And there's nothing special about the name "LAN": It's just a Unifi default, you could rename it if you wanted.
There's also nothing special about VLAN 1 except that it's untagged by default on most devices.
I mention this because a common mental model is that there's a real LAN and then other virtual LANs, that are somehow inferior.
But actually every VLAN is treated identically - Are untagged frames allowed on a port? If so, which VLAN does the switch associate them with internally? Are tagged frames allowed on a port? - and that's identical for every VLAN.
Switch port profile is tagging LAN as VLAN 1
