Virtualized Linux guest in FreeNAS 9.10 using iohyve
Hey folks. I wrote a blog post about using iohyve on FreeNAS 9.10 a few days ago and it was indicated to me that I should probably share it with the fine folks in this forum. Nothing spectacular aside from the fact that it allows you to install CentOS 7 as a guest where the iohyve github page says it's not possible (due to grub-bhyve not liking the default XFS filesystem). It may be interesting to some folks here (and my apologies if this isn't the best topic to put it into, but I couldn't find one more suitable).
The blog post is here:
https://annvix.com/blog/virtualized-linux-guest-in-freenas-9-10-using-iohyve
And I also just recently realized that Corral was out so while it's written for the older version it's probably mostly applicable due to the XFS limitation. Hopefully someone finds it helpful!
