Virtualbox jail not running after virtualbox-ose-kmod updated
amires
Hi guys, sure.
Firts off I started going through the guide as it tells you.
Remove virtualbox-ose, virtualbox-ose-kmod and libvncserver. (pkg remove ....)
I then start by installing libvncserver-0.9.9 (this wants to install openssl you can either accept this or force the installation, we wont actually need it)
  • pkg add libvncserver-0.9.9_5.txz
Next I installed virtualbox-ose and virtualbox-ose-kmod one of which have to be installed before another, it will tell you so you can't mistakely do wrong.
  • pkg add virtualbox-ose-5.1.6_1-b81cf4010c.txz
  • pkg add virtualbox-ose-kmod-5.1.6.txz
Copy of virtualbox-ose, virtualbox-ose-kmod and libvncserver here.
Done and enjoy!
Thanks for this however I had to use --ignore-missing parameter in pkg add commands to make it work. Now it is runnings perfectly with FreeNAS 9.10.2-U1.
shamo316
Hi guys, sure.
Done and enjoy!
im a newb lol, everything i try to pkg add i get this
pkg: wrong architecture: FreeBSD:9:amd64 instead of FreeBSD:10:amd64
shamo316
lee butler
please can someone tell me how I do this bit? do I copy the files to the jail?
lee butler
how do you do the --ignore-missing parameter
Darren Smith
Hi guys, sure.
Done and enjoy!
I've also successfully ran everything, but how do I tell FreeNAS to start virtualbox when I go to the Jail?
j0achim
Word of warning to all, only install this 'mod' if you are comfortable in the knowledge that the software may have been modified in some way (not that I am saying it is).
@j0achim, I recommend you link to the source code and provide instructions on how to compile it, instead of providing unverified links.
VirtualBox is unsupported as of 9.10.2-U1. Bhyve is available and is the hypervisor of choice within FreeNAS.
Yea I would link sources, unfortunately I scavanged the files from hours upon hours of google searches from old repository archives. I could look in my download log perhaps it tells me the source path.
golfleep
after getting virtual box working I now have this error? anyone seen it before? View attachment 16085
I get the same error without fail after varying amounts of time with I am logged into the virutalbox web interface. Sometimes it happens right away, sometime it takes 10-15 minutes, but it always occurs. Refreshing the page reloads the web interface. Don't know how to fix the issue though. Does not seem to affect functionality in anyway.
ArgaWoW
Have you done all the steps from the first post of this treat?
Gesendet von meinem LG-H850 mit Tapatalk
simplemal
Hi all,
as part of Feature #18630 Update to 2016Q4 Ports Tree is updated virtualbox-ose-kmod from 4.3.34 to 5.1.6:
current night build FreeNAS-9.10-MASTER-201612100422 (4d7d293)
[root@freenas3] ~# pkg info | grep -i virtualbox
virtualbox-ose-kmod-5.1.6 VirtualBox kernel module for FreeBSD
last stable FreeNAS-9.10.1-U4 (ec9a7d3)
[root@freenas] ~# pkg info |grep virtualbox
virtualbox-ose-kmod-4.3.34 VirtualBox kernel module for FreeBSD
Because of this update startup of Virtualbox VM in virtualbox jail fails and in "dmesg" output is error:
SUP_IOCTL_COOKIE: Version mismatch. Requested: 0x1a0007 Min: 0x1a0005 Current: 0x260000
Will you create new virtualbox jail template with 5.1.6 vbox version?
With 9.10 are many users using virtualbox jail and freenas 10 is not yet out.
If not, here are steps how to create new virtualbox jail yourself, for those, who want to still use virtualbox with current 9.10 version after update of virtualbox-ose-kmod to 5.1.6.
Before that, backup your machines in original virtualbox jail, so that you can move them to new jail after creation.
Steps to create new virtualbox jail
Jails -> Add Jail -> "virtualbox"
- this will create standart freebsd jail, do not choose old vbox template
jexec virtualbox
vi /usr/local/etc/pkg/repos/FreeBSD.conf
- url: "pkg+http://pkg.FreeBSD.org/freebsd:10:x86:64/latest",
+ url: "pkg+http://pkg.FreeBSD.org/freebsd:10:x86:64/quarterly",
pkg upgrade
pkg install virtualbox-ose phpvirtualbox apache24 mod_php56
adduser
Username: vbox
Full name: vbox
Uid (Leave empty for default): 1001
Login group [vbox]:
Login group is vbox. Invite vbox into other groups? []: vboxusers
Login class [default]:
Shell (sh csh tcsh git-shell nologin) [sh]:
Home directory [/home/vbox]:
Home directory permissions (Leave empty for default):
Use password-based authentication? [yes]:
Use an empty password? (yes/no) [no]:
Use a random password? (yes/no) [no]:
Enter password:VBox123
Enter password again:VBox123
Lock out the account after creation? [no]:
Username : vbox
Password : *****
Full Name : vbox
Uid : 1001
Class :
Groups : vbox vboxusers
Home : /home/vbox
Home Mode :
Shell : /bin/sh
Locked : no
OK? (yes/no): y
adduser: INFO: Successfully added (vbox) to the user database.
Add another user? (yes/no): no
Goodbye!
vi /etc/rc.conf
+ apache24_enable="YES"
+ vboxwebsrv_user="vbox"
+ vboxwebsrv_enable="YES"
service vboxwebsrv start
vi /usr/local/www/phpvirtualbox/config.php
- var $password = 'pass';
+ var $password = 'VBox123';
vi /usr/local/etc/apache24/httpd.conf
- DocumentRoot "/usr/local/www/apache24/data"
+ DocumentRoot "/usr/local/www/phpvirtualbox"
- <Directory "/usr/local/www/apache24/data">
+ <Directory "/usr/local/www/phpvirtualbox">
# In section <IfModule mime_module>, add after x-gzip type for php module:
AddType application/x-compress .Z
AddType application/x-gzip .gz .tgz
+ AddType application/x-httpd-php .php
+ AddType application/x-httpd-php-sources .phps
# workaround for older phpvirtualbox-5.0.5
vi /usr/local/www/phpvirtualbox/endpoints/api.php
- $response['data']['responseData']['phpvboxver'] = @constant('PHPVBOX_VER');
+ $response['data']['responseData']['phpvboxver'] = "5.1-0";
service apache24 start
ifconfig -a|grep inet
http://x.x.x.x
admin/admin
Enjoy!
I would create also template from this, but do now know how..
Kam
Hello Kam and thank you for this guide.
Before creating a new Jail I would like to ask you if there is a chance to restore my actual VBox's Jail with 9.10.2-U1. This seems perfect, but every time I start the machines I see the same error
http://pastebin.com/8cwqkF6y
Thank you so much
Ty8
Has anyone seen this error before? I followed all steps but can't seem to get past this error. I double checked the config.php file but I couldn't see any issues. I'm hoping this is an easy fix. Any help is greatly appreciated!
stillka
hi, virtualbox can't be installed regarding the how-to as "quarterly" release is now "virtualbox-ose-5.1.12_1.txz" which not work and 5.1.6 version is not available anymore... :-(
Tromm
Hi guys, sure.
Done and enjoy!
Hi @j0achim.
The links seem to be dead. Can you please, upload these files again?
Thanks!
Osiris
Could the ones with an operational virtualbox 5.1.x on a freenas 9.10.2-x host create a template using this method and provide us the files/links?
rosabox
I could do that, but how do I copy and cleanup my jail before I create a template from it?
Osiris
What do you refer to as cleanup? I'd set a new root password & that's it. Why the need to copy? The jail is not touched. After the template creation you can just start it again.
... Or I don't understand the question.
rosabox
I have a VM running in the jail, so I assume the config of the VM etc is stored somewhere in the jail.
The idea was:
1) I make a copy
2) I cleanup the copy
3) I create a template from the clean copy
4) I delete the copy
