I have router that has a public subnet which is in turn allocated to several machines, including my freenas box. I then run several different private subnets on the inside of the router which i can then use DNAT/SNAT on the public ips, to direct all/certain ports to differing hosts in the private space. E.g;
Router ip's;
- Public : 194.aaa.bbb.1/27
- Private : 192.168.50.1/24, 192.168.100.1/24, etc
FreeNAS ip's;
- Public : 194.aaa.bbb.17/27
- Private : 192.168.50.17/24
I installed a plugin jail, but wanted to keep the subnet seperate to everything else, so the jail configuration is set to user 192.168.100.0/24 and dish out ips in the range 192.168.100.100 - 192.168.100.200.
The plugin jail has been created as a VIMAGE (as its a seperate subnet from the primary network) and has the first allocated ip of 192.168.100.100, ive also added the default gateway of the router (192.168.100.1).
This has been working fine for a couple of weeks (im pretty sure i havent missed any steps out of my original config), as we have been using plex from this jail.
Today this all stopped working, where i am at the moment is as follows;
- From the router, i cant ping the jail ip of 192.168.100.100
- From the jail, i cant ping the router ip of 192.168.100.1, nor 194.aaa.bbb.1
- From the FreeNAS box, i can ping the router on 192.168.100.1, but not the jail on 192.168.100.100.
It would seem that i am now missing something between the bridge and the VIMAGE epair?
Any pointers/help are gratefully received. I can provide netstat's, ifconfig's, etc if required.
Router ip's;
FreeNAS ip's;
